Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Q about flex cables - Offshore Electrics Forums
Q about flex cables
  • j.m.
    • Jul 2008
    • 838
    Q about flex cables
    Would a .098 flex hold up to a 540 7L on 8 cells?
  • sailr
    • Nov 2007
    • 6927
    No no no. At LEAST a .150 cable or .187 even better on 8 cells!
    Mini Cat Racing USA
    www.minicatracingusa.com
    • j.m.
      • Jul 2008
      • 838
      Not fair!!
      I need to run 1/8" props. (mind you this is 8 cells nimh)
      • Steven Vaccaro
        • 8721
        You can probably get away with a .130 cable if you don't mash the throttle on starts.
        http://www.offshoreelectrics.com/pro...od=oct-oc64pkg
        • Jeff Wohlt
          • Jan 2008
          • 2716
          You will not hurt 130 with 8 cells. I had a couple big boats running 130 on 12 and 16 cells on 700 motors long ago. Never a problem.
          www.rcraceboat.com
          [email protected]
          • j.m.
            • Jul 2008
            • 838
            Alright. Thanks guys. I've only used wire drives before so I wasn't sure. :)
            • sailr
              • Nov 2007
              • 6927
              OH! You didn't say NiMh! BIG difference. Most of the talk on here is about lipos so I assumed you meant 8 LIPO cells! Even with 8S NiMh, the motor has too much power for .098 cable. The guys are right. .130 shaft will work OK. You can buy cables with stepped down shafts to 1/8". Steven has them: Product ID: oct-oc64pkg Octura .130cable system for 1/8" props. AND Product ID: oct-oc64pkgps Octura 3/16 to 1/8" prop shaft for .130 cable & 1/8" props
              Originally posted by j.m.
              Not fair!!
              Mini Cat Racing USA
              • j.m.
                • Jul 2008
                • 838
                lol, yeah. Old school.
                Can a 540L even take 8s?
