11XL on 6S is pushing the limits just that little bit too far. I run a 13XL on 6S with a X442 in my 31" cat and temps seem fine and I clocked 40-45mph (once). You'll have to run a small prop with the 11XL...
Newbee needing help...
Oki, I now think know have an Idea for a setup
For my 33" cat I'm thinking an 11xl on 6s (3x 2s 5000mAh 30c)
As for a prop I run the numbers to FEcal, an it suggested a octura M435/3 or grimracer 36x55.
According to FEcalc the amp pull is around 50amps +-.
Am I going of the deep end here boys??
580 10L 1,326 RPM on 6S you will be able to use a larger prop with that motor
The esc will have to be high voltage (rated from 5 to 12S) and I would suggest 120 amp as a minimum dependant on motor and prop. Check the forums for a suitable boat esc.
DouggieComment
oki,
shoping list:
540 13xl
120+amp HV
Seem that can't use the stuff I already have on this boat,
I'd better stop being a cheep, and fork up... hehe
Does anybody know when a 80a HV ESC can be usefull.
Thank you all for helping me, hopefully I can one day return the favor.Comment
If you are buying a new motor look at the 580 series for that hull length if you are on a budget. If not NEU
DouggieComment
