Newbee needing help...
  • Insanety
    • Jun 2009
    • 11
    The items in question are:
    Turngiy 80amp HV ESC
    and
    Turngiy 3656 2700kv
    http://www.hobbycity.com/hobbycity/s...r_(WaterCooled)
    As far as I know I can't use this combo, so I'm hoping somebody can guide me in the right direction. So I'm thinking if I buy the right motor and Ecs I have two "power packs", and a reason to buy a new hull.
    So If anyone can give me a gentle push in the rigth direction, I'd be a happy boater very soon...
  • FRED
    • Jul 2007
    • 233
    Newbie needs help
    Nothing.
    • Insanety
      • Jun 2009
      • 11
      Jupp, forgot to add type of hull etc.
      I'm currently building a 33" balsa/ply cat (plans from this forum).
      I could use the 3656/2700 in a 3s setup, but I'd need a new Esc.
      Or i could use the 80amp hv esc in a 4/5/6s setup and find an low kv engine.
      Not sure what is the best way to go.
      • sailr
        • Nov 2007
        • 6927
        You could either get this esc:
        or get a different motor. Cost is pretty close to the same. I would recommend buying a Feigao 1oXL motor from Steven at OSE.
        Mini Cat Racing USA
        www.minicatracingusa.com
        • Insanety
          • Jun 2009
          • 11
          Feigao 1oXL motor you say, on 6s? right??
          Don't you worry, I'm going to buy from steven very soon...
          • FRED
            • Jul 2007
            • 233
            newbie
            Nothing.
            • Insanety
              • Jun 2009
              • 11
              Fred:
              I understand, no need to go hogwild on lipos...
              3s lipo is something I have and need since i do rc planes and helicopter, so stepping up to
              6s (3s x2) is within reach. And since I help out my LHS, I get a good discount on lipos.
              Last edited by Insanety; 07-25-2009, 07:29 PM. Reason: missing words, sorry fred.. my bad
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                Okay some questions ...what batteries with C and amp rating...sport or race running....what prop....what hardware..proposed run times. A 33" cat will need at at least a 12XL running on 5S or 6s with a high voltage ESC rated at 120 amps or more dependant on the prop
                Douggie
                • domwilson
                  Moderator
                  • 4408
                  Here is some good reading... http://forums.offshoreelectrics.com/...read.php?t=271
                  Government Moto:
                  • Insanety
                    • Jun 2009
                    • 11
                    Douggie:
                    At the LHS we have some 2s 5000mAh 30c and some 3s 3200 25c.
                    Sport running
                    Props that I got is grim 40x53, and grim 40x52 3blade. open for suggestions.
                    HOR cat hardware.
                    Runtime?, how does 5min sound?
                    domwilson:
                    Thanks, have read it many times. Everytime I think I got it, I find somthing that dosen't compute and I'm non the wiser. A noob's tale...
                    • FRED
                      • Jul 2007
                      • 233
                      Newbie
                      Nothing.
                      • sailr
                        • Nov 2007
                        • 6927
                        On 6S you might want the 11XL or 12XL. I only run 4S. I'm pretty sure the 10XL would handle 6S but a little lower KV might be better.
                        Mini Cat Racing USA
                        • Insanety
                          • Jun 2009
                          • 11
                          Originally posted by FRED
                          Oops, i guess i stepped on your toes, i'll bow out!
                          I checked my toes (all 12 of them), non where hurting...
                          • FRED
                            • Jul 2007
                            • 233
                            newbie needing help
                            Nothing.
                            • Insanety
                              • Jun 2009
                              • 11
                              Oki, I now think know have an Idea for a setup
                              For my 33" cat I'm thinking an 11xl on 6s (3x 2s 5000mAh 30c)
                              As for a prop I run the numbers to FEcal, an it suggested a octura M435/3 or grimracer 36x55.
                              According to FEcalc the amp pull is around 50amps +-.
                              Am I going of the deep end here boys??
