Motor question
  • Shoei1
    • Jun 2007
    • 17
    Motor question
    Ok i got a 10turn motor from my 1/10th scale truck. I put it in my Graupner B-24 and i put a water cooling system on the motor. Well the problem is that the motor heats up so much the the wires come unsoldered(if thats how you spell it). Let me know if you need more info. Im new to boating and i need help.
    Graupner B-24
    How many cells are you running and what size prop? A 10-turn motor is too hot for a boat that size, particularly if you are running the stock prop. Boats are not like cars and trucks, you can't get away with low-turn motors if you want to run for very long - no/limited gearing, much more resistance, the prop creates a lot of drag on a motor. You will need to match the motor to the prop and cells you will be running. What do you want the boat to do, and with how many cells?
    • Shoei1
      • Jun 2007
      • 17
      Well i run a 6 3700 cell pack and i dont know the prop size. i took my caliper and measured it to be 31mm in diameter. when i got the boat it had a mechanical speed control and and what i think is a 550 motor. It had no markings on the motor so i took it to my local hobby shop. what i want to do with it is just make it go a little faster with the stock set up the boat wasnt lifting out of the water like it should.
      Graupner B-24
      • saleens7
        • 1108
        what would be better is to get a higher torque motor (like a 600 or 650) and use a larger prop....it will get you out of the hole better and may even gain i higher top speed...
        • Shoei1
          • Jun 2007
          • 17
          Would a 700 size motor be ok to get. i also have a lot of different car motors or should i just stay away from the car motors.lol
          Graupner B-24
          • ED66677
            • 1300
            Get one of these Speed700 with 12 cells and a K42 to K45 prop you'll have fun!!!
            Emmanuel
            • saleens7
              • 1108
              or you can also get the 700SC...
              http://www.offshoreelectrics.com/pro...prod=ose-700sc
              • ED66677
                • 1300
                yeah you're right!
                isn't it the same?:rolleyes:
                I managed to pull 40amps constant out of the Graupner one, not even warm!
                Emmanuel
                • saleens7
                  • 1108
                  i dont think so...the one you pointed out looked like a 700bb or just a regular 700...the SC is much more powerful...
                  • ED66677
                    • 1300
                    nope!
                    it's not a BB (no ball bearing), and it's not a regular one, the 700 Turbo C is pretty new, it is half way between high torque and high RPM
                    Emmanuel
                    • Shoei1
                      • Jun 2007
                      • 17
                      Ok so i got a car speed control also that has no motor limit well i think that means turn of motor not size like 500 600 700. will that speed control be a problem?
                      Graupner B-24
                      • saleens7
                        • 1108
                        motor size isnt what it means, i think it means the # of turns the motor has....you could use any 500-700 on any brushed esc as long as it doesent pull more amps or exceeds the # of turns the esc can handle...
                        • ED66677
                          • 1300
                          what type of ESC is this?
                          Emmanuel
                          • Shoei1
                            • Jun 2007
                            • 17
                            The link below is the speed control i have.
                            Graupner B-24
                            • ED66677
                              • 1300
                              go for the 700SC or the Graupner one (depends where you are and what's the easiest for you to purchase) and a K45 or 51 prop
                              Emmanuel
