Delta Force Cyber Storm 33 turning problems
    i dont turn left alot. but i do like to have that option. at the moment i need about 80% left rudder just to go stright
    That is so wrong and is likely the root of your turning problem. How much deflection is that at the rear do the rudder - in inches? What is probably happening is with so little rudder in the water, nothing is providing side force to counteract the prop walk. A deeper rudder should fix that. Is the weight inside the hull evenly distributed left/right?
    • ozzie-crawl
      • Sep 2008
      • 2865
      would also explain why its running so wet, lots of drag
      • video200
        • 837
        yes fluid the wight is evenly distributed.
        unshure what you meen by "How much deflection is that at the rear do the rudder - in inches" (sorry english is my seccond language).
        • video200
          • 837
          from the bottom of the boat til the end of the rudder is 1 3/4 i think (45mm).
          • ozzie-crawl
            • Sep 2008
            • 2865
            i think he means when your rudder is at 80% to keep it straight how far is the trailing edge of the rudder from centre
            • video200
              • 837
              when using my slide calliper from the center of the rudder and turn to aprox. 80% i get about 1\2 inch (7/16 to be exsact)
              • ozzie-crawl
                • Sep 2008
                • 2865
                thats a huge amount of drag. as fluid said you dont have enough rudder in the water to counteract the prop walk,then when you try and turn left the hull cant lean over much before the rudder comes out of the water. here is a pic of mine with they other rudder
                • video200
                  • 837
                  #23
                  gona order the same as you have as soon as steven wakes up and turns on for european shipping and se if that helps.
                  it shure do handle awsome in right hand turns though lol
                  • ozzie-crawl
                    • Sep 2008
                    • 2865
                    #24
                    yes mine runs in the mid 40s and there is no backing off even when i run in the small test lake
                    good luck
                    scott
                    • video200
                      • 837
                      #25
                      tnx.
                      i have no idea what mine is. but it almost holds up with a SV with some amo motor in it but ones i dont have to use the rudder just to stay stright and i get it less wet i should run sircles around it
                      what motor you have in yours ?
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        #26
                        iam only running a 9xl on 4s with a modded 447/3 prop. i only run for 2-3 minutes at a time.i think your setup with the rite prop should see 50 mph fairly easily if your not after long run times
                        • video200
                          • 837
                          #27
                          im going for something inbetween speed and runtime so time wil show what speeds i get out of this. but can always swap props back and forwars as to what i feel like that day.
                          • video200
                            • 837
                            #28
                            thank you for the help guys. realy apritiate it.
                            • Scott T
                              • Oct 2007
                              • 590
                              #29
                              Another thing to consider might be your tabs. They look flush with the bottom of the hull from the photos. Try lifting them up about 2mm (not angle, actually raise them up). Run the left one level, and try angling the right one down a degree or two (not much needed). That will help loosen it up a bit, and help it track straight.
                              Scott Tapsall
                              Pine Rivers Model Powerboat Club - Facebook Page
                              My Gallery
