he has it on there to greese.
leaking feigao water jacket
what do you mean Avengersteve?Comment
Glad you are good to go!
Here are the directions for the jacket.
OSE Water Jacket: Remove sticker from motor. Apply wd40 or similar to motor and jacket orings. Slide on the jacket. Make sure inlet/outlet are in the correct place, once set the jacket will not turn!
DON'T NOT PUSH BRASS TUBES THEY WILL BREAK!
Maybe the oring was twisted a bit. I've had zero returns from water leaking from the housing area. I had one return about water coming from the brass inlet or exit tube. It was poorly glued.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
clear enough!
nothing to add :DComment
