found this on another site, guy is having trouble getting decent speed from his rigger, i dont know if my sight is failing but it looks like the props backwards
the prop looks fine to me, I thing he may have to much positive angle and not enough strut in the water... it looks like a Ms Excess, right? she is probably sitting in the water (running wet). There is also NO room between the drive dog and the prop... friction is probably one of the bad ingredients too.
I am sure that Pat and Andy can chime in and give the owner a few good tips since they have leaps of experience with this hull.
Wow, lots of silly posts here! First off, putting the prop on backwards does not make the boat run backwards; the prop is clearly a normal left-handed prop. Second, it can't be installed backwards since the drive dog is engaged in the prop cutouts. Third, the prop clearly has some rake, although it appears from the photo angle to have a smaller degree of rake than some popular props do. That may just be due to the photo angle.
Poor speed could be from a large number of causes. Not enough pitch for the motor Kv; too much pitch is overloading the motor; drive dog rubbing on strut; wrong prop depth or angle; CG all wrong.....you get the point.
i knew when i posted this that someone would come up with a answer and i would look like an idiot but i put it up any way because every time i looked at the picture it just looked wrong. you can see that the drive dog slot is in the rite place but to me the blades just look to be around the wrong way
Hey ozzie I thought your meaning was obvious and going on the quality of some of the props that come from a certain manufacturer I would not be surprised if some do have the blades on backwards.
