Ul-1 esc and SV27 motor
  • Steven Vaccaro
    • 8723
    I have some customers looking for a lipo ready ul-1 esc with a stock sv27 motor. In theory it should work fine, but looking to see if any of you have had real work experience with the combo? If so how did the esc handle it?
    Steven Vaccaro
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    Confused Steven, which is normal for me are you asking if the UL1 ESC is compatable with the SV27 standard motor
    Douggie
    • Jesse J
      scale FE racer
      • Aug 2008
      • 7119
      I don't see why people wouldn't just use the much better motor of the UL1 set up. Unless this ESC is a replacement for the SV esc.
      "Look good doin' it"
      See the fleet
      • Steven Vaccaro
        • 8723
        Douggie
        yes
        Steven Vaccaro
        • Steven Vaccaro
          • 8723
          Because its not all that better for some setups. Sure for a hydro it is, but what about a heavier cat? Or big mono?
          Steven Vaccaro
          • Flying Scotsman
            • Jun 2007
            • 5190
            I can only say from what other members have stated that the UL1 ESC is prone to problems..Low voltage cutoff etc. which I have not experienced myself.
            Douggie
            • Jeff Wohlt
              • Jan 2008
              • 2716
              Look at the specs for the SV ESC and see if it also has 10 degree timing locked in. That is the only issue.
              www.rcraceboat.com
              [email protected]
              • Norman2
                • Sep 2008
                • 321
                Hi Steve. Spoke to Aquacraft folks today on this topic because that is why I ordered
                the UL-1 esc from you(Just sent Money Order). I am going to use it on my SV27
                powerplant. Aquacraft told me no problems. It is better for thw SVMotor more so if you are going to use Lipos. There is no problem using it with the SV Motor. Regards
                Norman
                34" Ekos Cat UL-1 Powered
                • Flying Scotsman
                  • Jun 2007
                  • 5190
                  Norman
                  I am now really confused, what was wrong with the original SV27 ESC and motor combination ??
                  Douggie
                  • Camman
                    • Jan 2008
                    • 77
                    I was fixin to ask the same thing Douggie
                    • Norman2
                      • Sep 2008
                      • 321
                      Ul-1ESC/SV27 Motor
                      Probably because the SV27 ESC is 45 Amps and No Low Voltage Cutoff and the
                      UL-1 ESC is 60 Amps and has LVC. Regards
                      Norman
                      PS. SV27 ESC is designed for Nicd/nimh Batteries
                      • detox
                        • Jun 2008
                        • 2318
                        In my UL-1 I have used large props (detunged x645) with the SV27 motor/esc combo without a problem...other than the motor getting VERY HOT!
                        LVC of the UL-1 esc is a joke. Yes it will stutter, but then die suddenly on pond.. Maybe the newer UL-1's will not have same problem. I hope you do not pop a cap using the UL-1 esc.
                        • Jeff
                          • 232
                          Are the motor connectors not differant sizes between the two? Maybe not a plug and play for some.
                          I try and avoid paste eaters.
                          • Norman2
                            • Sep 2008
                            • 321
                            Sv27/ul-1 esc
                            One is 3.5MM the other 4MM. Easy to fix
                            Norman
                            • detox
                              • Jun 2008
                              • 2318
                              You will need 5.5 bullet connectors. Those cheap thin Aquacraft connectors heat up too easily and will melt soldered connection. Do not cut motor wires...simply unsolder then solder bullets on.
