Ul-1 esc and SV27 motor
    • 9488
    Originally posted by Norman2
    Probably because the SV27 ESC is 45 Amps and No Low Voltage Cutoff and the
    UL-1 ESC is 60 Amps and has LVC. Regards
    Norman
    PS. SV27 ESC is designed for Nicd/nimh Batteries
    The SV esc works just fine with lipo batteries...
    • longballlumber
      • 3132
      LVC or not... I would not recommend anyone to continually run there LiPo's down to the LVC. You should be timing your runs and bringing the boat in BEFORE you hit the LVC.
      It increases the life of the LiPo's
      It decreases heat in the entire system
      It decreases the chance of swelling lipos which can lead to a fire
      Just my $.02. You guys make the choice...
      Later
      • Norman2
        • Sep 2008
        • 321
        SV27Motor/UL-1 ESC
        Hi, Thanks for your input, I am new to lipos. Would you consider a 5 minute run
        time OK. with 2X2S1P25c 5000MAH on a 29"Titan Mono with X640 prop.
        Thanks
        Norman
        34" Ekos Cat UL-1 Powered
        • D. Newland
          • Dec 2007
          • 1030
          Keep your runtime to 3 minutes until you have a good handle on your amp draw and cell/motor/esc heat.
          After you know this info, you can adjust your runtime, but 5 minutes will not happen with that setup. 4 minutes may be do-able. My LSO race setup is a BBY Patriot 28" mono, UL-1 motor and ESC, X642 d/t, 4950 mah 28c Marinepowers and 4 min's is it.
            • 9488
            Later
            I've ran my UL-1 till the lvc kicked in and now I think I have a hurt lipo..
            • Norman2
              • Sep 2008
              • 321
              Hi, Thanks, Will try four minutes and if need to will go down to three. I wonder
              what batteries would I need to get to 5 minutes comfortably. Thanks again for
              your help.
              Norman
              • D. Newland
                • Dec 2007
                • 1030
                Do 3 minutes first, then work you way into 4 minutes.
                Here's the math: That setup is +/- 60 amps on average. Therefore, you are burning 1000 mah's every minute of runtime.
                If you want a 5 minutes AND your setup is confirmed 60 amps on average, then you need cells that can comfortably put out 5000 mah's. So, you really need a 6000 mah (Poly RC) or 6500 mah (Neu energy) cell to do it. I'd favor the Neu's as they are the latest generation cells.
                • ozboater
                  • May 2007
                  • 415
                  #23
                  as a relative newb who is looking to jump to lipos soon, there is some real good info here !!
                  cheers
                  • Norman2
                    • Sep 2008
                    • 321
                    #24
                    Hi OZ Boater, Man it was so easy with brushed motors and NIMH Batteries, but
                    progress is needed. Quite a change, Regards
                    Norman
                      • 9488
                      #25
                      possibly going with some 4s 3000-3500mah packs in parallel ?
                      • Steven Vaccaro
                        • 8721
                        #26
                        I am now really confused, what was wrong with the original SV27 ESC and motor combination ??
                        Douggie
                        "looking for a lipo ready ul-1 esc "
                        • D. Newland
                          • Dec 2007
                          • 1030
                          #27
                          You can parallel your way to 6000 or 6500 as well. I favor going 1P on the spec classes because the cells will then be flatter...and the weight will be lower in the hull. Probably means and amounts to nothing; just one of my quirks.
                            • 9488
                            #28
                            Kinda like this???
                            • Norman2
                              • Sep 2008
                              • 321
                              #29
                              Hi Newland, Just came back from the lake running my Titan 29 and was able to get
                              3 1/2 minutes and everything seems OK. I think probably could have gone 4 min.
                              but wanted to make sure how much it discharged. One of my friends was running
                              another Titan with UL-1 Motor/Esc and he was using a new SMC 2S1P 7.4 lipo with
                              8000 MAH repeat 8000 MAH and he ran almost 8 minutes. He got them at a Local
                              Hobby Shop in Easly, SC which is about 2 hours from where I live. Will have to check
                              this out. If they are available I will get two and be a happy man. Again Thanks
                              Norman
                                • 9488
                                #30
                                can the SV motor take 5s or 6s like the BJ26 motor can?
