Set Up questions??
hello;
I might be able to help if I knew what you are powering up.What do you have for electronics.and size of motor,kv...how many turns?The mah as I understand is the run time you have and the c rating would e good at 25c with at least 40-50c mah rating.We can start there...... Have a good one
AlComment
Yes, I think they will work fine. any reason for the 2p though? If not I would go for a single bigger pack, charging 2 packs is a PITA when compared to 1 larger 5000mah 3s pack.Paul Upton-Taylor, Greased Weasel Racing.Comment
Mini Cat Racing USA
With that battery in parallel you will have 88amps cont. Should work out..NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
The reason i am going with two 3s in parellel is because my motor KV is too high to run 4s. But i did order some big 5000mah batteries already. My plan was to buy these then when my 5000's came into stock i would use those.
Heres the new idea:
