graupner GTX-650 OB questions
  • saleens7
    • 1108
    what size prop does it come with?
    is it meant as a surface drive or sub-surface?
  • SJFE
    • 4735
    I think the max prop on that unit is 33mm. they are the the threaded style. There are adaptors to run 3/16th props. But the cavitation plate limits the size. Steven has told me they will not hold up to a brushless app.
    • saleens7
      • 1108
      BL...i was going to keep is brushed....i will switch out the 540 motor in the SW26 once i want to make it faster....then ill save up and buy the OB unit for it and put an outboard on it....
      • Steven Vaccaro
        • 8721
        Glad you asked, when I opened the box to look for the size, I noticed graupner no longer includes a prop with the outboard that doesn't come with a motor.
        Tom is correct about the size. Max is 33mm. The outboard with the included motor has a 31mm prop on it.
        • saleens7
          • 1108
          hmmm...maybe i could use twin 650 OB's...ill just use the other speed contol piranha2 gave me and buy some cheap 6 cell packs...should make a quick little boat....
          is a surface drive or a sub-surface drive?
          • Steven Vaccaro
            • 8721
            Subsurface
