Bullet connectors...best way to install them.
  • Capt. Crash
    • Jan 2009
    • 301
    ok guys...newbie with bullet connectors in hand is ready to cut off the deans on the lipos and solder up castles 5.5mm bullets. Question...is there a standard way to arrange these...ie....female connectors on the battery and males on the esc? That is the norm with the other connectors...but here is the problem I see with that. Unless the wires or shrink is color coded you're asking for smoke! Check the pic out of the UL-1 setup....the series connection has 2 black wires but one of them is connected to the positive. How do you know which is the correct wire to plug the positive female battery lead into if they are the same black color using the same male connector?
    My thought is to use a male on one battery lead and female on the other...that way you can't plug into the wrong connector....but which lead should have the male plug...positive or negative? Again...what is the standard.
    Thanks
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3225
    I've seen folks put either male or female on the positive or negative. I believe that most put both a male and a female on the same battery. Yes, it is tempting to plug it into itself, but this is avoided by fashioning a cap on the end of the male connector to prevent this.
    The reason why people put both male and female connectors on the same battery is to allow running the batteries in series.
    SERIES: ESC - to - Batt 1 + to - Batt 2 + to + on ESC
    Hope this helps.
    • AndyKunz
      • Sep 2008
      • 1437
      I suggest using females on the battery for both. Use different colored heat shrink for polarity, and make sure the heat shrink (when both mated and open) completely covers all the copper.
      If you mix them, there is the possibility of the male touching the female and starting a fire. If they're both female, that can't happen.
      Andy
      Spektrum Development Team
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7128
        MY norm is this: males on the motors, females on the ESC. Batteries, positive female, negative male (so I don't get nuttin crossed).
        However, I have received electronics with all combinations so it remains to be your own convention.
        I use a plumbing torch to get things hot enough. Flood the little chamber with solder then cook it for a couple more seconds until solder pervades the wires. In the end do what you like, then keep doing it on all your stuff. it takes seconds to change things so just get started....
        "Look good doin' it"
        See the fleet
        • Meniscus
          • Jul 2008
          • 3225
          Oh well, I guess there's all kinds of setups. I think it is a personal preference.
          Andy's recommendation is the safest option.
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7128
            Andy, good point about capping the male bullet on the batts. Will start doing that, thanks for the tip.
            See the fleet
            • Capt. Crash
              • Jan 2009
              • 301
              Ok...so what I'm hearing is there's no standard with this....and yes Andy, females on both sides of the battery would be safer especially when ya toss all the packs in a lipo sack... If I had a piece of red shrink tube to use it would be easy...but of course nothing is ever easy with me, so I will need to find another way to mark the black male connector to show it's the one that goes to the red female in that harness...otherwise....I play "On top of ole Smoky"
              • Meniscus
                • Jul 2008
                • 3225
                If you PM me your address, I'll drop some in an envelope for you. You can always change out later. What color would you like? I believe I have red, green, yellow, blue, clear, and maybe some other colors.
                • Jesse J
                  scale FE racer
                  • Aug 2008
                  • 7128
                  How many you gotta make? I can send you 6" of red shrink if it would help. pm me your address and I can fire you off a strip in today's mail.
                  See the fleet
                  • Jesse J
                    scale FE racer
                    • Aug 2008
                    • 7128
                    Meniscus you think like a genius.................
                    See the fleet
                    • Jeff Wohlt
                      • Jan 2008
                      • 2716
                      So how do you hook cells together for series with all females it won't happen.Packs come with the correct colored wires so how would you miss that no matter what conenctor?
                      www.rcraceboat.com
                      jwohlt5362@yahoo.com
                      • Meniscus
                        • Jul 2008
                        • 3225
                        LOL!
                        This is the reason why I stated one female and one male on the first response, that is, if he wanted to run in series.
                        • line6
                          • Aug 2008
                          • 478
                          I have mine female on the + and male on the - of the bat. I have it like this for 2 reasons #1 you cant hook it up backwards by accident .#2 the + has no metal exposed so there is not much off a chance you could short it on any thing. also I always keep the + side covered in till i am ready to plug it in ( heat shrink works good for this just don't heat to much)
                          • Capt. Crash
                            • Jan 2009
                            • 301
                            Wow...good stuff....I love the forums!
                            Thanks for the generous offers guys...a piece of red shrink will solve the ID issue on the series harness above.
                            Jessie pm sent...
                            Jeff...look at the harness...it has 2 black wires going into a red and black connector...if you choose the wrong black wire....what would happen?
                            I'm still undecided on females for both battery connectors or the line6 suggestion which is red female/black male....that one sounds good if I use a protecting cover (hmmmmm) on the male...and is less like to short than with a male on the positive wires.
                            • FRED
                              • Jul 2007
                              • 233
                              bullet connectors
                              Put a piece of heat shrink on a connector of which will be a different color, like Andy said. Then plug the correct ones together and then heat the shrink and then cut a circle around each and never a hook-up problem again unless your blind in one eye and can't see out of the other,LOL!
