DF Vortex is in. YAY. Dumb question though
  • Blackjack-sven
    • Feb 2009
    • 371
    #31
    If I used a 5000kv Cyclon motor and an x430 prop would that work out?
    HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
    • Jesse J
      scale FE racer
      • Aug 2008
      • 7116
      #32
      sven, you want to try to stay around 30-35K RPMs on these hydros. I run (on my similar sized 1/14th Atlas - my avatar) 8L on 3S and an X632 and get about 60-80 amps pretty constant with 120 amp spikes. Use this as a guide. You will quickly decide not use a 5000 kv motor. That is such a tiny prop and think about when you are hopping in and out of the water, you are talking serious amperage fluctuations....
      "Look good doin' it"
      See the fleet
      • Blackjack-sven
        • Feb 2009
        • 371
        #33
        has anyone seen this before?
        • Blackjack-sven
          • Feb 2009
          • 371
          #34
          I also saw this here.
          • tth
            • Apr 2008
            • 1510
            #35
            Spicedcrab was the screen name of the guy who built the vortex in the last link. Check here in the forum.
            • Blackjack-sven
              • Feb 2009
              • 371
              #36
              Where do you guys put your cooling exits? Are there bad places to put them? I was thinking of placing mine on the left side right behind the sponson.
              • Jesse J
                scale FE racer
                • Aug 2008
                • 7116
                #37
                I like mine to shoot straight up, that way I can see that they are working, plus added spray!
                See the fleet
                • properchopper
                  • 6968
                  #38
                  I recently did that[behind the sponson] to my 31" H&M Shovel. Unfortunately the spray from the sponson covers the exit[s] while underway and I've yet to find out if the cooling system is flowing properly. Try to locate them where you can see the output while running.
                  • Blackjack-sven
                    • Feb 2009
                    • 371
                    #39
                    I had to pick up a new cable system so that I could run the x430 prop but the plastic liner won't slide into the stuff tube.
                    The cable is .130 thick OD
                    The liner is .194 thick OD
                    The stuff tube is .185 thick ID
                    So unless my math is really THAT bad this should fit right?
                    • Jesse J
                      scale FE racer
                      • Aug 2008
                      • 7116
                      #40
                      some people stretch it a touch while they insert, you can put one end in a vise and then pull it (thus decreasing that OD) and then insert it into your tubing. I will be getting the next size up to avoid this step, even though the math does say it should fit...
                      See the fleet
                      • Blackjack-sven
                        • Feb 2009
                        • 371
                        #41
                        Is the liner really that nessecary? Cant the stuff tube be filled with lube? What is the liner used for?
                        • Jesse J
                          scale FE racer
                          • Aug 2008
                          • 7116
                          #42
                          The liner helps protect the cable. You can run without, but increase friction and potentially wear the tubing faster. Depends on rpms you are working with, the higher the faster you use up your lube. It is debated though whether the liner is "necessary". I prefer wire drives, but have some cables and all but my micros have liners. Supposedly the liners will hold up for a long time, especially with lots of lube. I am sure there are lots of other opinions, so I guess its not super critical either way.
                          See the fleet
                          • Blackjack-sven
                            • Feb 2009
                            • 371
                            #43
                            So I guess if I lube the tube before each run I'd be fine eh?
                            • Jesse J
                              scale FE racer
                              • Aug 2008
                              • 7116
                              #44
                              what rpms? what hull? How much load on the the drive? If it spins fast, metal on metal will not only be louder, but will wear faster.
                              It also depends on how you drive. I am sure you will be fine, you can go with a smaller stuffing as well. You might want to get some more opinions from people who have more experience with cables that will bring up points you may want to consider.
                              See the fleet
                              • Blackjack-sven
                                • Feb 2009
                                • 371
                                #45
                                I'm not sure about the rpm's exactly but I am using a Feigao 6xl in the vortex, and it will be turning an x430 prop. What do you mean by "how I drive" ?? If you look here at my youtube video you'll see how I drive.
