Prince Mono Hull
  • M.M.
    • May 2009
    • 264
    #61
    how does that motor work? Is the hardware good? And have you had any problems with the motor mount and servo mount breaking loose? I have heard that the R2 version had the wooden stringers that broke away.
    • B-DAWG
      • Apr 2009
      • 42
      #62
      Mine is a 380 L size motor it runs good and temps are around 120 degrees. (www.fsd-motor.com) I reinforced the stringers on the motor mount with little stripes of cloth and resin. I thought the hardware was pretty good. You got to think about it's a $260.00 boat with shipping. Mine on 3S will out run a SV27 on 4S. I'm still trying to get it set up right. I ran it today the first time after I painted it and put the esc in it also. It's got a little chime walk right now. I'm sorry I don't have a GPS so as far as speed I have no idea. I'd say mid to upper 30's right now.
      • M.M.
        • May 2009
        • 264
        #63
        Well so far i am happy with my purchase(even though it hasn't shown up yet)
        So you are running the motor hat came in it right? if you are will only a 380 sized motr fit? I want to put a fiegao 540 in mine.
        • B-DAWG
          • Apr 2009
          • 42
          #64
          Yeah same motor. I wanted to do the 540 thing but I was going to order a DF hull, water cooled 540 mount, and transfer everything over but they are not instock. Alot of things are not instock at offshore right now (fiegao 380 L motors also). I thought with summer here they would be in full swing.
          • tth
            • Apr 2008
            • 1510
            #65
            Steven ordered quite a while back, I believe its Delta Force thats backed up. B-Dawg how's your ESC working out?
            • B-DAWG
              • Apr 2009
              • 42
              #66
              Real nice!!! Again Thanks TTH I ran it for the first time today (I got everythiing set at default) I'll start playing with it more this weekend the rain cut my time short today
              • M.M.
                • May 2009
                • 264
                #67
                So how hard would it have been to remove the stock motor mount before you glassed it in? Would this one be a direct replacement?
                http://www.offshoreelectrics.com/pro...rod=tfl-502b12 is the watercooled mount needed?
                • 785boats
                  Wet Track Racing
                  • Nov 2008
                  • 3169
                  #68
                  MM.
                  I don't know if that mount is the same width to fit in between the rails. That's something you will have to measure when you get the boat.
                  I don't use a water cooled mount in mine & if you have a good water jacket on your motor you won't really need it. That all depends on how much you load up the motor with your prop choice of course.
                  I don't know where the waterways run in the mount that comes with your boat. but what I would try first, if it were mine, is drilling two new mounting holes for the 540 motor. It's only 1/8" difference & I'd bet London to a brick that you won't hit a waterway.
                  If you do? Well you were thinking of buying a new mount anyway.
                  Just a thought.
                  Paul.
                  • bustitup
                    • Aug 2008
                    • 3071
                    #69
                    Originally posted by 785boats
                    MM.
                    If you do?
                    Paul.
                    sounds good but make sure you only take 1/16th" off each side
                    • 785boats
                      Wet Track Racing
                      • Nov 2008
                      • 3169
                      #70
                      Sorry bustitup, but that's 1/8" each side. The 380 motors are 3/4" apart & the 540 motors are 1" apart.
                      Just had a thought, if it looks like the holes will be too close to the existing ones you may need to rotate the motor 20 degerrs or so to put a bit more space between them. Might be easier to drill that way without the drill running into the existing holes.
                      Cheers.
                      Paul.
                      • M.M.
                        • May 2009
                        • 264
                        #71
                        i never thought of that.
                        The boat is awaiting customs inspection in the U.S. so i should hopefully receive it soon. how could i take an 1/8 inch out?
                        • Simon.O.
                          • Oct 2007
                          • 1521
                          #72
                          Pauls suggestion to rotate the motor and drill new holes is the best option unless you hit a water gallery.
                          If it were mine I would either drill new holes 90 deg out or file the existing holes to slots. I have a couple of mounts like that.
                          Centering the motor in slotted holes can be done a few ways. Let me know if you want to take either approach and have any more questions.
                          PM is good.
                          • 785boats
                            Wet Track Racing
                            • Nov 2008
                            • 3169
                            #73
                            Old Yeller.
                            Here's a link to the flood chamber pics I posted on R/C Groups in the 'Bulletproof ' thread, as requested. Scroll down to the bottom of the page.
                            Thanks again to Jan (pompebled) for the instructions.
                            Cheers.
                            Paul.
                            • ozzie-crawl
                              • Sep 2008
                              • 2865
                              #74
                              that looks good paul were does the batterie sit, does it lay up against the side of the flood chamber
                              on a side note is boondalls restriction just 4s or 4s 1p
                              • old yeller
                                • Apr 2009
                                • 21
                                #75
                                flut-canal
                                Old Yeller.
                                Cheers.
                                Paul.
                                COOL.
                                I must say that "Bulletproof" was one of a very few rcbt1111 builds
                                that inspired me to pursue my project – i.e. one that was "well done".
                                And thanks, Paul, for the time & effort to post the flood-chamber build.
                                (bookmarked 4 future reference, as was Pompebled's instructions)
                                anxious to hear how it works out for you "on the pond".
