I have a Titan 33 with Fine Design hardware that I just dropped a 1515 1Y in. With the new or shall I say Neu motor she ran strong but was chine walking pretty bad. The strut was set neutral and level with the keell. I got 47 mph out of her with a X640. I was hoping for a little more. Anyhow the B-mono guru in my club told me to drop the starboard tab a bit. I did and the chine walking was reduced significantly. When I got home, I did a little search on OSE and RRR and found numerous remedies for chine walking. Change strut height, change strut angle, change prop, drop port tab, drop both tabs, change CG.
Just for giggles, a few days later I ran out to the pond and set the tabs back to neutral and raised the strut up 1/16", keeping it neutral. This seemed to eliminate the chine walk but I was wondering if there is a preferred sequence in dialing in a new hull to correct porpoising or chine walking. Does using tabs increase drag more than making a strut adjustment. Does it not matter what you do as long as you get the proper running attitude? Or is it just a matter of trying them all and seeing which adjustment gives me the best GPS numbers?
