help need brushless info !!
  • Jcarlton
    • 400
    i have a m tronics genesis brushless motor and esc comb . but when i program the esc the motor twitches weird . but what i need to know is it the esc or the motor . im running 12 cells in series or combine the 2 for max voltage . they are ib 3800 6 cell batts . any help would be appreciated . steve help me out man !!
  • NorthernBoater
    • 811
    What specific motor and speed control is it, model number and name. Does it do this when the radio is on?
    • Jcarlton
      • 400
      go to mtronics .net to get the full info but yes the esc wont go light up to program if the remote isnt on . but its a m tronics genesis truck esc rated at 12 cells has a average discharge rate of 80 amps max 120 . and the motor is a 600 can size 3000 kv . was made as a replacement for the e-maxx . thanks northenboater for your time. what do you think ?
      • NorthernBoater
        • 811
        If this only happens when the radio is on I would say something is wrong with the radio. Check to make sure your throttle adjustment is at 0. On mine if it is not, it will do weird things.
          Have you read the instructions? The last paragraph of the instruction sheet below may answer all your questions. Note the word "screeching".
