Rudder pushrod-linkage
http://www.rcfastboats.com/ -
I have heard of people using SS welding rods for linkage. If your linkage sections are straight you can use hollow carbon/fiberglass rod as a reinforcment.Comment
You won't believe it. I have these as well, 2 or 3 mm I think. They are super strong and much stronger than the ones I mentioned above. I tried to make thread in the past but no way, there4 left them aside, they are really difficult to bend as well. But now I can epoxy the clevis or ball joint on one side and on the other side the ez connector. I will find them again, thanks. These I got from a shipbuilding yard.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
i spend most of my time at work tig welding so i have a ready supplie of 1.6-2mm s/s rod, but found thicker rod at a local hobby shop they have 4-40 (i thought 4-40 was a imperial measurment of some kind but this may not be rite) they have them for planes with a threaded end with or with out clevis there made by du-bro http://www.shopatron.com/product/par...161.5165.0.0.0Comment
Is this rod s/s or galvanized?Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
Thanks Curt. I will check on these as well.
Yesterday night I reassembled (again) the linkage. Tried to fit the s/s welding rods (I have 2, 2.4 and 3mm rods) soldered the threaded coupler but finally decided to use the 2mm rods which are threaded on one end, fitted a Sullivan clevis there (servo side) and an ez-connector that i found on the rudder side. Let's see how it will perform. Relocated also the servo as close as possible to transom.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
on my boats i run a clevis on the servo side and on the rudder end its hard to explain look at pictureAttached FilesComment
Clevis or ball outside, at the rudder horn , ezi-connector inside at the servo horn.
Really it is so hard ??
Wait untill I have the new rudder setup for a Cat I may build.
Designing and building the hardware is half of the fun, I have most of the rudder setup done.See it....find the photos.....sketch it it....build it........with woodComment
I ordered some 4-40 push rods and various connectors as well, just in case. I saw that the 4-40 is 0.093" diameter which is about 2.4 mm.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
this is were i should say somthing about sheep but will leave that alone
my rudders have that setup and and works rather well
on another note here is a link you may or may not have seen has some good info http://boatdesign.net/articles/tunne...sign/index.htmComment
I use these on the servo end (solder)
Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
I use these on the rudder end up to 4S boats.
Just a note on the dubro swivel ball links. I get the version for the 2-56 then I redrill the plastic and thread in my 4-40 rod. Works Great. I also always use the speedmaster mini (.21)
rudder assembly. The hole in the rudder are are already the correct size to tap a 2-56 thread into it.Comment
Nice. Which 4-40 rod are you using? Is it s/s or galvanized?
There are the Dubro Heavy Duty 4-40 ball links available also which I suppose fit the 4-40 rods.
