Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Rudder pushrod-linkage - Offshore Electrics Forums
  • DINO7
    • Jan 2009
    • 162
    #31
    i think that this is the best product for FE pushrods.
    Adjustable Alloy Push rod/brace 2.6x90mm
    Adjustable Alloy Push rod/brace 2.6x110mm
    H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
    MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
    BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
    • longballlumber
      • 3132
      #32
      Originally posted by DISAR
      Nice. Which 4-40 rod are you using? Is it s/s or galvanized?
      There are the Dubro Heavy Duty 4-40 ball links available also which I suppose fit the 4-40 rods.
      http://cgi.ebay.com/Dubro-Heavy-Duty...713.m153.l1262
      At this point I am only using galvanized, because I usally need to make a bend of some sorts. However, if I can get the servo/rudder set up so the push rod is straight, i would try and use the SS stuff.
      Problem with the actual HD Dubro stuff is the size, it's just physically too big for the size of boats I am running 30" and under.
      Mike
      • crrcboatz
        • Jan 2009
        • 914
        #33
        Try smaller bicycle spoke wire for smaller boats and the bigger stuff for your large boats. Can buy it at any bicycle shop or even off an old bike.
        • DISAR
          • Aug 2007
          • 1072
          #34
          Originally posted by andym
          I use these from Andrew G at Fastelectrics.com , just scroll down to near the bottom of the page, http://www.fastelectrics.com/hardware.asp
          These Dubro connectors do the work! Thanks
          http://www.rcfastboats.com/
          • rickwess
            • Apr 2013
            • 777
            #35
            An old thread, but the same issue. I'd like to use 3mm stainless for my linkage, but I can only find 3mm fully threaded.
            What's everyone else using? Is 2mm stainless strong enough?
            • properchopper
              • 6968
              #36
              Welcome to ServoCity where you can get the parts you need to bring your ideas to life! From servos to switches, from actuators to Actobotics, we work hard to bring you the best components backed by unparalleled technical support
              • rickwess
                • Apr 2013
                • 777
                #37
                You guys in the US have all the interesting RC stores.
