How to hook up motor in Syncron
  • paulwilliams
    • May 2007
    • 82
    Originally posted by Gerwin Brommer
    I always thought that Toysport uses normal cables , like 4,75mm
    I made some replacement flexis for the stinger on a friend's Syncron. The cable was 0.150" into a 3/16" shaft.
    Paul
    www.fastelectrics.net
    • Steven Vaccaro
      • 8721
      Most all the shafts I've seen on his rtr boats are 5mm with a 3/16" end and 150 cable
      • paulwilliams
        • May 2007
        • 82
        Hmm - maybe they were 5mm -> 3/16" - I'd have to check.
        Paul
        • H2OCamel
          FAST ELECTRIC EVERYTHING
          • Oct 2007
          • 484
          Well my caliper says the cable is 0.147 inches?
          "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
          • paulwilliams
            • May 2007
            • 82
            0.003" is within the cable tolerance - 0.150" is only a "nominal" size.
            Paul
            • H2OCamel
              • Oct 2007
              • 484
              Steven,
              any tips to help setup my syncron? cg? photos of interior layout?
              • Jeff Wohlt
                • Jan 2008
                • 2716
                5 mmx 150 then.
                www.rcraceboat.com
                [email protected]
                • H2OCamel
                  • Oct 2007
                  • 484
                  #23
                  Yes!
                  And the cap came off in seconds with the torch it must have been loctite.
                  • Steven Vaccaro
                    • 8721
                    #24
                    Steven,
                    Does yours have a flood chamber? What cells are you running with the 8xl?
                    • H2OCamel
                      • Oct 2007
                      • 484
                      #25
                      I have been running 4s (2packs of 2s in series) with a x637 prop on a similar sized mono and i'm swapping that combo to the syncron. Yes it has the flood chanel in it.
