How to hook up motor in Syncron
  • H2OCamel
    FAST ELECTRIC EVERYTHING
    • Oct 2007
    • 484
    I need help hooking up an 8xl to my toysport Syncron it has a 5mm tip on the end of the flex shaft. so I need a 5mm to 5mm coupler? where do I get one? or what else will work?
    Thanks,
    Chris
    "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
  • Jeff Wohlt
    • Jan 2008
    • 2716
    I replied to you on RRR. No problem making you a 5x5. Mist be a 4mm cable with solder on it making it a 5mm...is that possible?
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • H2OCamel
      • Oct 2007
      • 484
      I bought the replacement cable from offshore electrics and yes it is a solder on cap. the cable that came with it was modifird so that it couldn't be removed without cutting off the end which i did. I also replied to you in e-mail too for the coupler Thanks a million!
      • Steven Vaccaro
        • 8723
        Jeff can make you a nice one. My question is what coupler was in the original boat?
        In order to get the flex out without cutting it, first remove the teflon. The teflon has a slit in it and pull out towards the motor side, than the flex will come out without cutting it.
        • Gerwin Brommer
          • Dec 2008
          • 918
          5mm ? how strange !
          What is the diameter of the original cable ??
          • Steven Vaccaro
            • 8723
            Gerwin, Joseph puts a sleeve over the flex cable. It works well with the set screw type couplers.
            • Gerwin Brommer
              • Dec 2008
              • 918
              Okay. Not my style of connecting :-)
              • Jeff Wohlt
                • Jan 2008
                • 2716
                Steven is right and you have to pull the teflon. Some across the pond did this with wire drives as well and then it was removed as one unit but allowed them to clamp down on the insert brass harder without damaging the cable when using set screw couplers.
                You probably should change it over if you want. I can make the coupler to what the cable size is if you want. It would be esier to service later. Should be able to break that apart with some heat. Then find out the cable size, which may be metric but we can get it on the money.
                let me know before I start the lathe tonight. I would bet it is 4mm shaft.
                www.rcraceboat.com
                • Gerwin Brommer
                  • Dec 2008
                  • 918
                  I always thought that Toysport uses normal cables , like 4,75mm
                  • Jeff Wohlt
                    • Jan 2008
                    • 2716
                    You are probably right...I really do not know the cable size. I would put a mic on it to be sure so we do not make one too big.
                    www.rcraceboat.com
                    • H2OCamel
                      • Oct 2007
                      • 484
                      When I get home tonight I will check it out.
                      • Jeff Wohlt
                        • Jan 2008
                        • 2716
                        Just let me know in MM and decimal. If you have a decent caliper.
                        www.rcraceboat.com
                        • H2OCamel
                          • Oct 2007
                          • 484
                          I have a good pair of calipers but I'm not finding them
                          I will take the shaft with me to work in the am. and get the measurements there and send them to you. What kind of heat will I need to remove the cap? will a propane torch work? Will I need to solder the end then? It would be nice to be rid of the cap for greasing and ease of maintanace.
                          • Jeff Wohlt
                            • Jan 2008
                            • 2716
                            Torch it! It is either solder or Loctite.
                            www.rcraceboat.com
                            • H2OCamel
                              • Oct 2007
                              • 484
                              A now my pyro side takes over :D
