driveline question
  • all8up
    • Feb 2009
    • 17
    driveline question
    I am interested in purchasing the .130 flexcable that includes the teflon liner.. the one that needs to be assembled..
    the question I have is what strut do I need to make this work? would a 1/4 strut be best? so i could fit the brass stuffing tube inside the front of the strut?
    or do I need a 3/16ths? and with that one, would it attach to the brass tube, or just leave a small gap between the tube, and the strut? thanks
  • calcagno45
    • Mar 2008
    • 1006
    For the .130 cable, you'll need to get a piece of 7/32 brass stuffing tube to house the cable. And for the strut, you'll need a 3/16 strut. The 1/4" struts are for larger boats that run .250 flex cable.
    • SJFE
      • 4735
      In my opinion 130 cable are on the lighter side as far as durability. If your running 4s in a 30+ boat look into a .150 cable system.
      • all8up
        • Feb 2009
        • 17
        ok, i got the .130 kit with the teflon tubing today, and the 7/32 brass tube.. but the teflon wont fit inside the brass tube!!! is there a trick to this? or do i need a bigger brass tube?
        • Steven Vaccaro
          • 8723
          You can either stretch it a bit, our use some sandpaper, curl up the sandpaper and slide the Teflon in and out of it.
          • all8up
            • Feb 2009
            • 17
            OK thanks for the reply!!!
