Kb45 motor mount
  • bustitup
    • Aug 2008
    • 3071
    Kb45 motor mount
    ok I did some searching and didnt find any definitive motor mount to fit this motor that will work in my mm...here I have this motor mount i'm trying to modify but it looks a little flimsy......or should I start with a new fabrication
    any ideas here?
    yes I know i was told I should remove that old gas stuff but I kind of like it because it seems to strghthen the tunnel real nice and I like the radio box so I'm going to use it for the initial running
    here is my 10xl with water cooling and my himodel 8s esc with water cooling going to run it with 6s and 8s starting with a x442 prop
  • Steven Vaccaro
    • 8723
    That mount is light for a big motor like that. If you do use it, make sure to support the back of the motor with a small piece of wood.
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      The ESC and 6 to 8s on that motor
      Douggie
      • ghostofpf1
        • Jun 2008
        • 392
        Lonewolf here made a nice motor mount for mine not too long ago...maybe ask him for another ??
        Steve
        • bustitup
          • Aug 2008
          • 3071
          Steve
          Was it the same style I need with the old gassrr perch?
          • lomdel
            • Nov 2008
            • 708
            Douggie
            That motor pulls a LOT of amps, are you sure the HM ESC will handle it. Do the calculations first, dude!
            • bustitup
              • Aug 2008
              • 3071
              What about the turnagy 100 amp 12s
              • bustitup
                • Aug 2008
                • 3071
                ok this is the info I got from Mr Watts
                KB45 10xl
                8s
                x442 32016 rpm, 92 amps, 2537 watts, 52 mph
                x440 32365 rpm, 76 amps, 2131 watts, 53 mph
                y537/3 32881 rpm, 69 amps, 1947 watts, 55 mph
                6s
                x442 24765 rpm, 58 amps, 1241 watts, 42 mph,
                x445 24190, 76 amps, 1596 watts, 44 mph
                x447 23753 rpm, 90 amps, 1859 watts, 45 mph
                x642 24268 rpm, 74 amps, 1549 watts, 47 mph
                x645 23564 rpm, 96 amps, 1970 watts, 49 mph
                • TotalPackage
                  Banned
                  • 601
                  That motor can handle 6s-8s where did you get the water cooler? I desperately need one.
