im doing a special build that i will reveal later, im using the stock sv27 motor, and am need of an esc capible of reverse. i would like for the esc to be able to hadle at leat 8 cells so i can keep the power to the motor high for speed reasons. any sugestions.
what esc
Tags: None
A Barracuda 80 can be set-up with reverse active, and would be plenty of ESC for your application...Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby." -
Be careful if your going to use a cable.
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
VERY good point... Cable is directional... On the Castle controllers, you can set the percentage of throttle that reverse can be... 12.5%, etc... I'd set it to a low setting since it's only for dinking around... Otherwise, you may unwind your cable and cause yourself a mess...Darin E. Jordan - Renton, WA
yeah i was thinking about that.. i was going to keep reverse at ex treemly low powerrestoring the collectionComment
