Help with a brushed motor for a hop up...
  • SweetZ28
    • 1322
    Hi Guy's I own a few boats that come with a stock 550 motor and i tested the RPM on one out of my Hammer boat with my RPM checker and it was 17.100rpm @ 7.2V now what i am getting at would this motor be a good hop up for a little more speed at a great price of only $15.99?
    Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
    here are the specs:
    S-600 Stock number: GPMG0710
    S-600R Stock number: GPMG0715
    Designed for: 7.2-8.4V
    Includes: motor w/capacitor
    Requires: leads
    Winds: 19 turns of 0.80 mm wire
    Max. RPM (unloaded): 21,900-24,500
    Current (unloaded): 2.5-3.3A
    Timing: 3°
    Rotation direction (GPMG0710): counter-clockwise
    Rotation direction (GPMG0715): clockwise
    Output shaft diameter: 0.125" (3.18 mm)
    Output shaft length: 0.38" (9.6 mm)
    Output shaft shape: rounded
    Can diameter: 1.43" (36.5 mm)
    Can length: 2.25" (57 mm)
    Endbell type (GPMG0710): closed
    Endbell type (GPMG0715): open
    Rotor assembly: epoxy balanced
    Bushing type: bronze
    WWW.PPRSLOTS.COM
  • Jimmy Sterling
    • Apr 2008
    • 393
    Where there any specs for the motor (under load) ?
    The RPM rating (no load) does not mean much
    But being a 19 turn 600 will allow you the spin a slightly larger prop
    Have you had a look at Graupner's line of brushed motors ?
    Come to the FASST side
    • Steven Vaccaro
      • 8723
      Under load at about 70%, you are at 17k or so. When you measured 17k on your hammer, was that underload or on the bench?
      • SweetZ28
        • 1322
        Hi Steve it was on my Ice charger using motor break in @7.2V using a 10 amp supply and I got the RPM readings with no load on the motor nothing conected at all to it.
        WWW.PPRSLOTS.COM
