Himodel gx series 125a esc...anyone
  • bustitup
    • Aug 2008
    • 3071
    Originally posted by yurkanip
    If I am understanding you correctly, bustitup....You are asking about the mosfets, (fets) right?
    If that is what you mean, then NO you don't want to encase the fets, but around them yes. Just make sure the tops are wiped clean, then lightly sand when it is all dry. The tops of these are what heats....the sides as well, but heat rises and it exits out that area. everything else should be epoxied. its too hard to heat the epoxy and esc, at the same time so heating the esc, After the epoxy has been slopped on is the easiest. This is true, since dp-270 has a working life of 70 mins.....giving lots of time to heat it and rotate as the epoxy drips to get into every single part of the esc...(well, as far as possible...since the 200amp escs have 3 boards sandwhiched together...getting it down in between those will be a task, but heat and apply the epoxy, it will work for sure)
    accually I was refering to the capasitors....but I needed the info on the fets too
    • Simon.O.
      • Oct 2007
      • 1521
      For those of you who have the himodel 125A speedy.
      The specs show cell input at 3-6 lipos or 5-20 Ni cells
      If it will run on 5Ni cells then surely it must run on 2S lipo ??
      Can one of the owners of these esc's see if it will spin up a motor on 2S lipo
      I am planning on using it on a 540 8S in my balsa fleet.
