TFL Lucky Oct
  • Big J
    • Jul 2022
    • 5
    TFL Lucky Oct
    I have a TFL Lucky Oct that I can not get handle. Just can not get it to run straight or turn. Even on the straight line it china walks really bad.
    Yes I have tried to raized and lower the stinger but onkly a little help. This boat has a 4082 with 1600 kv. Any help I just can not run this boat.
    Thank you Jeff
  • leski379
    • Jul 2023
    • 93
    Thank you Jeff
    What % is your CG? That hull only has turn fins correct?
    • koen
      • Mar 2020
      • 357
      check the flex from the rudder blade and the extention from the rudder ,i had the same problem and it appeared that the rudder set was very flexible i changed the rudder unit compleet and no problem any more(this hull is a MHZ AGGRESSOR so not a RTR boat)
      • leski379
        • Jul 2023
        • 93
        Also check to make sure your rudder is square to the boat, and your turn fin/fins. Heck even the stinger
        • Bande1
          • Mar 2023
          • 680
          take the electronics out and pitch the rest in the trash. build you an MLBoatworks wild thing or a delta force from OSE.... and a set of trim tabs.
          soon zippkits is releasing a P mono kit and a 6s rigger. that'll be great.
          • Big J
            • Jul 2022
            • 5
            Thank you I will check the rudder
            • Big J
              • Jul 2022
              • 5
              this boat only has 1 rurn fin on the right side.
