SAW propeller for Hydro 2
  • Veloctiykingsracing
    • Oct 2021
    • 15
    Or an 1823 or 1925. Says the guy who was going to run a 36mm can in a jae 33 and just figured out they fit 4070 cans. How many saw runs have you done? Collected data? Let's see the vids.
    • Bande1
      • Mar 2023
      • 680
      I will be working the clock at the official IMPBA time trials next week. stop on by and set a record.
        • Oct 2021
        • 15
        Only concern would be due to their crap rotors would be if the prop was able to spin airborn unloaded. Go ahead, stick with your 1400kv on 8s. And then post video of your speed. I've run 3200 kv on 8s successfully for data. I've consistently run speeds of 125 to 132mph. With that comes experience, not what written on paper. Vids are all there.
        • Bande1
          • Mar 2023
          • 680
          you can prop up 1400kv. you dont need high rpm. you get less slippage and much safer rpm's. why run it on the ragged edge? furthermore, TP makes comp motors specifically for doing this. a 2319 will get in the 125mph range with that KV. you can even run 1/4 props. 6719 3 blade.
          I dont run SAW but ive seen plenty of smoked motors, esc's, and batteries.
            • Oct 2021
            • 15
            Yes tip speed, slip all come into play. Again, I wouldn't personally use An Sss motor for a Saw run. I can come up w a lot of positive and negative remarks regarding it's use BUT to answer the question, yes a SSS 4092 2000 kv will be fine for an 8s saw run. Never said it was the best choice, never said it was optimal or the worst choice. The user has to try it in his setup and collect his own real data. Not paper data. I hit 105mph in my Pursuit(vid is online) MONO, that was using well over 2000kv on 8s. Now most would say you can't do that or it's wrong. Then again, "most" haven't broke 100mph in a mono so their point in moot.
            • Bande1
              • Mar 2023
              • 680
              its a 4082. and nobody is saying you cant run 2000kv on 8s. Im saying that motor specifically isnt made for that. CM/SCM motors are 3000kv on 8s rated. they have special wiring and rotors to do it.
                • Oct 2021
                • 15
                4082 or 4092? Either way, don't use a SSS motor for SAW would be the best answer. Use a TP.
                • tbonemcniel
                  • Sep 2020
                  • 295
                  #23
                  Originally posted by LibertyMKiii
                  I am interested in trying 3 blades as well.
                  My logical conclusion is that having a blade in the water 33% more often per RPM will net a much higher load on the motor. It would be wise to start with a 2 blade and see where things are with temperatures and then move to a 3 blade.
                  Having a higher amperage draw will result in lower RPMs and in some cases this is why more blades = less top speed. The setup has to be optimized for 3 blades.
                  That's not the case, like, at all. It's a general rule of thumb that a 3-blade will have a slightly higher load than a 2-blade, but typically by one prop size. So to have equivalent load moving from a 2-blade to a 3-blade, prop down one size and the load is similar.
                  Again, just a rule of thumb. A few months ago I had a 39" 6S Mono I was running a 1917 2-blade on. I moved over to a 1917 3-blade prop without making any other changes to the boat. Left COG, strut settings, and trim tabs where they were, and guess what. Amp draw went down, temps went down, top speed went up, and the boat was more stable.
                  • fweasel
                    master of some
                    • Jul 2016
                    • 4286
                    #24
                    With your SAW experience, what do you prefer to use prop wise, in reference to the OP's original question? I've only ever found 3 blades to be useful on problematic monos where I needed more prop but couldn't continue to increase diameter. 2 Blades have always been a more efficient option for my SAW boats, but I don't have any hydro experience.
                    Vac-U-Tug Jr (13mph)
                      • Oct 2021
                      • 15
                      #25
                      Use a 2 blade. More efficient and less drag. Aside from what is written on paper, one would have to really do trial and error to see if they would make gains w a 3blade for the conditions and hull setup. Each prop will have its sweet spot w a hull and given conditions. It really boils down to getting out there and put in the time with a setup, a bunch of props and collecting the data. Many can suggest what would be best but the truth and reality will come from one's own testing. Save your data logs, write down your observations. Review and assess after testing. When my mono hit 105 and many runs over the 100mph point, it required alot of testing. No one could suggest an answer or prop that would be the best, despite them also maybe owning a Pursuit. Acquire some props in the ball park area, test and assess.
                      • Ivan Kozyakov
                        • Apr 2022
                        • 81
                        #26
                        Guys, thank you for the hot discussion and advice. I have ABC 1817 and 1917 2 blades and I'll start with that. Does it make sense to buy the 1717 or is it too small for my setup?
                        • LibertyMKiii
                          • Dec 2018
                          • 127
                          #27
                          Specs online say the Hydro-2 is 990mm long (38.9").
                          I know the JAE 33 FE likes the 1817 prop and is only 33" so I would suspect the 1717 might be small for this boat? Ultimately the diameter is something you would change depending on how it is running. You will have to test and see how it runs and then make decisions from that point.
                          This is where an ESC with data logging comes in handy to help you make educated decisions instead of guessing.
                          • NativePaul
                            Greased Weasel
                            • 2760
                            #28
                            Which Hydro2 is it Ivan?
                            While I don't have a JAE33 to compare I did have the old JAE.21FE that I ran in hydro2 for a while and it was the heaviest and hardest to push Hydro2 I've had, so while hydro2s have grown since then so has the JAE and I should imagine that while it may be bigger Ivan's boat will be lighter than the JAE33, it likely has fatter ride surfaces, is more aerodynamic and has aero lift too, all of which make it easier to push.
                            Personally I like to start with as small a prop as I think will work, tune the boat on it and work my way up tuning as I go, which reduces the likelihood of running a super wet setup pulling a lot of power which can burn things up, or worse a loose setup at very high speed that can result in a big splash and the loss of your boat the first time out. Props are always useful to have and are cheaper than ESCs, motors or hulls. I'd buy a few props and start with a 1614, with the end goal being 1819 if it has the temps to get there and the hull to do it.
                            On the subject of aero lift nearly all Hydro2s have it to some extent or another in order to maximise efficiency and minimise lap times for 6 minutes with limited energy, Naviga racing has a very different hull requirement than SAWs, and for SAWs you may well have to find ways to ditch some of that lift.
                            • Ivan Kozyakov
                              • Apr 2022
                              • 81
                              #29
                              My boat is Dr.Super Evil from Hydro&Marine (890mm) with custom SAW sponsons. My result in this season is 134 kmh at setup:
                              4082 2000Kv SSS motor
                              180A Seaking ESC
                              6s 5000mAh 100C battery (2*3s)
                              1817 ABC prop
                              Weight with batteries 1980g.
