Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Newbie here looking for next boat - Offshore Electrics Forums
  • TonyM995
    • Aug 2023
    • 20
    He’s got a carbon fiber one also in stock. The adrenaline junkie in me automatically wants the 51” dual motor hahaha.
    Here is my last time out at the track last year on my zx6.
    This year I’m building a 2022 Hayabusa and am having a turbo kit fabricated for it. I’m almost done and just haven’t filmed any update but I started with an unterminated harness and did all of the wiring myself.
    • fweasel
      master of some
      • Jul 2016
      • 4286
      I use OSE 8mm anti-spartk connectors on all of my 4S and 6S batteries, which is what you'll be running in a boat this large for 8S, 10S, and 12S configurations.
      Here's a picture of the setup I had in my 56" Genesis
      I shortened the length of the hydraulic rams and inserted a carbon fiber plate shim in between the rudder mount and hull to correct the steering travel limitations:
      The solder joint on the stock flex cables was terrible and created an imbalance. They both needed to be replaced.
      • Xrayted
        • Jan 2023
        • 274
        Nice Bike! Yes, that is boat I have. Mine is the carbon version. The ARTR version comes with a 1650KV motor, which is still perfect for heat running with 6S batteries. I bumped mine up to a 2000KV motor that I already had laying around, and a more aggressive prop, and I easily hit 80mph with straight-line SAW type runs, but be aware heat starts to become an issue with any FE boat once you start pushing things to the edge like that.
        You will need to go through every part of TFL ARTR boats like that. The hardware is just finger tight in many circumstances, so its just essentially showing you where the parts go, but a good way to get a package deal until you become more familiar and can comfortably do a custom build using all the parts sourced yourself.
        The only true RTR boats on the OSE site are any of the more mainstream Pro Boat versions from Horizon Hobby. Those are pretty much plug and play for the most part for the beginner masses, but some of them are quick! I have a Pro Boat Miss Geico Twin myself, and that is a 100 MPH straight line boat with nothing more than custom props
        Here is a pic of my current TFL. I use a canopy from the fiberglass version so that GPS will work in the boat since CF block the signal. I painted it flat red to have a contrast between the shiny carbon and the canopy, but more to make the boat easier to see when sitting out on the water, as its low profile just looks like a shadow out there in certain light sometimes, plus all my water cooling is also red to match
        • TonyM995
          • Aug 2023
          • 20
          FWeasel/Ryan- wow Thats a beautiful boat. Thanks for sharing the pictures!
          xRayted/Tony- damn I love the red hatch and carbon hull. I will definitely do something similar if I end up with a carbon hull.
          It is clear that I need to pump the brakes and learn/read more. Ryan I know you have a build thread I can dig through and Tony if you have one let me know.
          I know wiring for motorcycles and cars but everything is 5 volts to read from sensors and the main fuse is 30 amps. A fuel pump, rectifier, and fan are the outputs that draw the most current.
          300 amps is still mind blowing to me and I have seen myself being impatient like this (wanting something now) enough times that it is clear to me the same happened here.
          I fried the electronics on my m41 this weekend by holding it wide open an entire battery pack. Hopefully the batteries are okay. Ordered the upgraded motor/esc from OSE Steve and it seems like that upgrade will be somewhat comparable to what the 36” Ariane has. I got a temperature sensing gun and instead of using it to check the heat and have a better understanding of the load the electronics were experiencing, I just pushed and melted them. Oops, my bad. That proved to me I am being impatient.
          My current thought is to get the m41 going again, keep reading here, and talking to everyone here. Then I’ll likely go with something 50” to handle the waves.
          To honor the impatient little boy that apparently still lives inside me, I joined the Jeffco Air Modelers and will buy an airplane to play with. They have a super nice field in the same state park that I run my boats at. This will give me humans to talk to and play rc with.
          You guys can repair and setup these boats. I do not have any experience with that and with the plane it was suggested I buy some certain glue and repair items. It seems like there will be some cross over with learning how to work with and repair the rc plane/boat. The entire plane and parts are $400. A guy there is selling me a used remote for $250 so that is not bad to get started.
          • Xrayted
            • Jan 2023
            • 274
            Wow that sucks things got cooked on your M41! Was the upgraded prop you mentioned in the OP a bigger or higher pitch prop from stock? As stated before, brushless motors/ESCs are more efficient when running wide open, but you must make sure you have adequate cooling as well, or any setup will eventually fail from overheating if not. I know it doesnt matter now, but as you learned, always bring the model after a minute or so and evaluate the temps
            I made the same mistake pushing things too far on my twin Miss Geico when I first got it. The boat is already right on the edge stock of being able to keep cool with the stock 1716 props on 6S, but I was running a set of hotter speed props and kept going for one too many laps in a row and she just shut down. The there was a loud "pop" sound about 30 seconds later and then smoke out of the nose!
            Once retrieved I discovered that one of the ESCs had caught fire, and the pressure caused the nose of the FG hull to split at the seam because it was taped up so tightly! I never got the soot and smell out of the hull as I originally wanted to repair it, but just decided to toss it out and start new.
            I would have known the cooling limits with that different prop if had just brought it in a bit sooner and checked the temps.
            Good luck!
            • TonyM995
              • Aug 2023
              • 20
              Haha I’m just glad it was on the m41 vs a twin engine that would cost a lot more to fix. The temp gun was left at home so all I can do is laugh at myself.
              It does matter and that’s great advice to bring it in after a minute. Before I was doing that because the drive strut would not stay in place and that would really over heat the electronics. I finally had that in good alignment and it wasn’t moving at all during the run. So I stopped bringing it in and was just hanging too much fun jumping the waves out in the middle of the lake. I went way out in the middle vs standing at the shore.
              Thanks again for all of your help!! Thanks for sharing your melt down too, glad I am not the only one. :)
              Here is the prop I bought. It seems identical to stock but made of stainless. Before this I had the brass one; it bent from a stick or something in the water so I got the stainless one. It seems like learning about different props is a great next step for me.
              • Xrayted
                • Jan 2023
                • 274
                Yikes, $79 for a CNC prop on Ebay! It doesnt say what the specific diameter and pitch is though, and only says "hot racing" in the description which makes me think its a more aggressive prop than stock, and possibly why your RTR boat got overheated.
                Find out what the stock diameter and pitch is, and you can get one for $20 here in the future if needed: https://www.offshoreelectrics.com/ca...CNC+Propellers
                • TonyM995
                  • Aug 2023
                  • 20
                  Yeah that’s what happens when people try to get into a hobby like this without the help of others… I got the 2 year plan for free but this has to rank up there in not the best use of money. I’m happy to have more guidance now.
                  It has a lot of cavitation when trying to get going.
                  using the search function here would have helped a lot before buying but I hadn’t found the forums at that time.
                  “The stock prop is 42mm x59mm which = 3.82 total pitch.”
                  https://forums.offshoreelectrics.com...p-vs-cnc-props
                  The one I bought says this if you click on Full Description:
                  Prop diameter: 42mm (1.65 inch)
                  Prop pitch: 63mm (2.48 inch)
                  • Xrayted
                    • Jan 2023
                    • 274
                    Good info thanks! So it is a hotter prop at about 4 inches of total pitch vs the stock 3.8 (diameter X pitch = total prop pitch). Not a huge difference from stock, but stock is already a high pitch prop to begin with, and it could have been enough to overheat things going even higher, especially if the stock setup was already right on the cusp of being able to keep things cool enough to begin with.
                    • NativePaul
                      Greased Weasel
                      • 2760
                      If you want some fun in rough water i would consider moving to a self righting mono rather than a bigger cat, if you stayed at a similar size to the M41 you could transfer the electrics and save a fortune, or even if you want to keep both runnable a <3' boats costs a hell of a lot less to power than a 4' one, and while a 4' boat will be more capable in the rough stuff you will be much more willing to take a smaller self righting hull up to and past its limits of capability, which can be a LOT of fun.
                      • TonyM995
                        • Aug 2023
                        • 20
                        Hey Paul, great point and i would be open to that if I could find one that excites me. Did you have one in mind? I have a 27” Thrasher v3 on 6S; it is a jet boat so not fast but I drive it up rapids backwards on a river by me and its a lot of fun in rapids . The pro boat sonic wake 36” seems to be the only self righting boat around. Oxidean dominator it’s another choice but the things I read on here about BO are not great.
                        For the roughest conditions it seems the TFL Princess 51 looks to be the king but it probably doesn’t fit in my car haha and is not my style but it looks fun!
                        I love the look of the yellow Arrow Shark but they seem wildly overpriced and I cannot justify that price for a boat where I live. Someone told me I could get kicked out of the state park lake where I go but the people that have seen me run had nothing but positive feedback so idk.
                        To your point it does feel a lot ‘lighter’ to have a lower cost toy you can run hard and not worry about breaking it or burning up expensive electronics. I would really like a TFL Ariane 51 but do not think I am quite ready for it in terms of my knowledge of this hobby. Plus I would hate to spend that much only to get kicked out of the state park lake I use.
                        Picked up a plane to use at the rc air field. Joined the club and the president will help me or any new members with assembly and flight lessons. So I have that to play with as I figure out a good intermediate boat which will be a mono for sure now that I have more input from you guys.
                        • Peter A
                          • Sep 2012
                          • 1486
                          #27
                          The Sonicwake would be a good choice for now just to thrash and bash. There are a number of upgrade parts available and plenty of threads etc on upgrades.
                          • NativePaul
                            Greased Weasel
                            • 2760
                            #28
                            The Ecomaster big slider or RCsails hulk are top banana 4-6s self righting monos if you dont care aboutu scale looks, or the hydro and marine speedman is still much better than the typical RTR and pretty scale looking.
                            • TonyM995
                              • Aug 2023
                              • 20
                              #29
                              How is Bonzi customer service and boat quality? I called them and he said any of their boats can be made for electric. He is going to send me an email with a few options for mono hulls.
                              Here are calm conditions for me that I took today at 6:30 am. My guess is a FE catamaran would not be as fun as you all mentioned.
                              The boat in that video is a Thrasher v3 on 6S lipo. It can take anything you throw at it. Normally I bring it to man made rapids and can jump off a rock wall down to the lower level water and rip up the rapids backwards. It is fun but I prefer faster boats.
                              Whatever I buy has to excite me and a Pro Boat or equivalent is a step down from the two boats I own. Thanks for the discussion!!!
                              • fweasel
                                master of some
                                • Jul 2016
                                • 4286
                                #30
                                The Thrasher is a nice boat. The M41 is plastic entry level, and no worse than anything Proboat has. Bonzi does quality builds. Their Epic 60 is one of the best v-bottom hulls around in that size.
