Tools for the hobby
  • kck741
    • Aug 2007
    • 265
    Tools for the hobby
    I was wondering if anyone keeps a multimeter in there toolbox for troubleshooting there boats and cars in the hobby
    S.S.R.C-Southern Style Radio Control
  • Diegoboy
    • Mar 2007
    • 7244
    I do.
    • tth
      • Apr 2008
      • 1510
      I do also. I keep a Fluke 179 Multimeter.
      • egneg
        • 4670
        Originally posted by Diegoboy
        I do.
        You do? I seem to remember you asking if anyone had one at one time - maybe you do since then.
        IMPBA 20481S D-12
        • kck741
          • Aug 2007
          • 265
          im trying to get a stationary meter for the work bench got many meters i use for work
          • 10gauge
            • Aug 2007
            • 281
            My measuring tools consist of:
            1. A steel ruler made by Wescott either 12in or 18in, $5
            2. Digital Vernier Calipers, $20-30
            3. Multimeter, $25
            4. Accurate scale, $15
            5. Eagle Tree, $70+
            6. USB Link to ESC, $20
            You don't need a complex multimeter unless you're modifying motors and ESCs internally. All you need is to read DC volts and Resistance. An EagleTree is important for modifying setups, prop, motor, and Lipo changes- sensors to record amps, volts, rpm, heat, time.
            Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
            • ksm2001
              • Jun 2007
              • 377
              I second the Eagle Tree , one of the best tools you can have! Without the Eagle Tree its like using a blank ruler, "good guesstimate"
              I use a cheap mutimeter to just check the volts on my packs during the winter storage if I don't want to use my charger to check them.
              Cheers
              Ken
              DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
              • ED66677
                • 1300
                Yep multimeter and Eagle Tree... and laptop!
                Emmanuel
                • Meniscus
                  Refuse the box exists!
                  • Jul 2008
                  • 3225
                  Yes! A multimeter and duck tape. You never know when another member may get out of line.
                  • kck741
                    • Aug 2007
                    • 265
                    what type of meters would you guys suggest for the hobby I dont want to use my good meters for the boats but i want one just for the hobby
                    • Jesse J
                      scale FE racer
                      • Aug 2008
                      • 7116
                      If you have the Eagle Tree data logger, do you need the watts up meter? or is it the same/better?
                      "Look good doin' it"
                      See the fleet
                      • ron Olson
                        • 89
                        I picked up a digital multi-meter from Harbor Freight, a big whoppin' $4.00 .
                        Member, Southwest Michigan Model Boat Club.
                        • ED66677
                          • 1300
                          The Eagle Tree records what ever you want it to, volt amps rpm temp... once you get back home (or plug it to a laptop at the pond) you can download from it and get some addittional info like power, cumulative mAh, also a 2D graph where you can see all these datas.
                          You can also buy a LCD display that allows you to view these datas at the pond without laptop, this is really a great tool for electric models.
                          Emmanuel
                          • Jesse J
                            scale FE racer
                            • Aug 2008
                            • 7116
                            I just got my data logger and went to hook it up and was wondering if someone might be so kind as to photograph how they have set theirs up. I am interested in capturing draw/load to help me with experiencing a little less unmagic smoke (never liked calling it magic, its very un magical - maybe if there were sparks too then maybe magical). The manual is not exactly explicit enough for me, maybe someone who has this guy figured out might post a pretty picture.
                            I am thinking I need a y harness to go from the ESC, to both the logger and the rx. Is this all I do? then if so, do I hook it up to Trott or RPM? I ain't measurin RPMs yet, just want draw.
                            Thanks
                            See the fleet
