Important Questions
  • hide
    • Dec 2008
    • 188
    #31
    The spec I gave them was of a heavy hull and they gave me this as a suggestion. I have to use it once so I have documentation for the exam board that it actually runs, then I can use a bought hull.
    • hide
      • Dec 2008
      • 188
      #32
      So does anyone know what I can run it on? I already have the motor and ESC.
      • hide
        • Dec 2008
        • 188
        #33
        Bump: Would appear I got the measurements tangled; it is 34" not 39".
        • hide
          • Dec 2008
          • 188
          #34
          Bump, again.
          I've received all my parts. Just need the motor coupler and that should be all minus the batteries. The actual hull is nearly finished too.
          How do you put a flat spot on the motor shaft? I'm guessing at a file when held by a clamp, but am not sure.
          I'll have some more questions about getting the drive line setup soon, but at the moment its all still in it's packaging.
          • AndyKunz
            • Sep 2008
            • 1437
            #35
            A cutoff wheel in a Dremel works better. Put a sheet of plastic around the motor to keep the metal from getting inside.
            It doesn't take much to make a good flat. Don't do too much! You shouldn't need a clamp, either.
            Andy
            Spektrum Development Team
            • hide
              • Dec 2008
              • 188
              #36
              Ok, that was because I was worried about was the shaft spinning whilst I was making the flat point.
              Should I need to cut the cable down, do I solder the cut end so that it will not unwrap when I run it?
              • AndyKunz
                • Sep 2008
                • 1437
                #37
                I used to run cables until I upgraded to piano wire, so I'm a little foggy, but I think I used to solder them. It makes sense.
                Andy
