ID some hardware anyone?
  • BrickBait
    • Jan 2019
    • 50
    Have a look at these pictures below...
    Can anyone name the manufacturer of these rudders and drives?
    I think the first one is a MTC rudder, and the second a speedmaster rudder.
    Looking to equip a MHZ Racemaster with either i Single Inline setup, or a dual rudder/single drive setup.
    Going into some rather uncalm water with this
    What would be a good distance from transom to leading edge of rudder in both setups?
    And distance from transom to drivedogs?
    Hope someone can share some experience with this boat size
    Cheers - Frank
  • Alfa Spirit
    • 2131
    This RC Boat Bitz is fine:
    This one is great too:
    • fweasel
      master of some
      • Jul 2016
      • 4309
      MTC rudder, drive, trim-tabs
      TFL rudder and drive
      MHZ rudder, unknown drive
      MHZ rudder, MHZ Trimax arneson drive
      • BrickBait
        • Jan 2019
        • 50
        Thank you
        But I guess they are hard to get then. Looks like MHZ has pulled them from the shop.
        I do like the looks of the first one. MTC. Looks like 145mm from transom to leading edge. Isn't that a bit to long? Looks quite long.
        I am trying to find info about what rudder length I need + distance to transom. And also how long a strut I need.
        Cheers - Frank
        • fweasel
          master of some
          • Jul 2016
          • 4309
          MTC product is nearly impossible to get at the moment. MHZ stocks some of it, so check there first. Don't even bother trying to order it directly from MTC. Still waiting nearly 8months for my last order. I believe MHZ has discontinued the Trimax drive.
          • koen
            • Mar 2020
            • 363
            i have a mhz phantom (it's the same hull)i run it with the setup as in the 2 picture with a tp 4070 1400kv without the trim tabs and turn fins and it run so good this hull is easy to setup
            • BrickBait
              • Jan 2019
              • 50
              Sounds good koen.
              What is the distance from transom to front edge of the rudder ? And from the bottom of the hull, to the bottom of the rudder ?
              Cheers - Frank
              • koen
                • Mar 2020
                • 363
                form transom to edge rudder 12cm and form bottom hull to bottom rudder is 7cm
                • Alfa Spirit
                  • 2131
                  If you want large size and high quality hardware have a look to WD200.
                  Further development of the proven rudder 38
                  for large monoboats, black anodized with line polished rudder
                  Length of the rudder boom to rudder axis 140mm or 202mm
                  Rudder blade length 135mm from lower edge cheek, total height 205mm
                  Order no.5043
                  Length with 140mm boom =165 mm
                  Price rudder with 140mm boom: 189,00 € incl.19% VAT plus shipping
                  Paypal price: 196,55 € including 19% VAT plus shipping order / order
                  Order no.5044
                  Length with 202mm boom =227mm
                  Price Rudder with 210mm boom: 211,00 € incl.19% VAT plus shipping
                  Paypal price: 223,60 € including 19% VAT plus shipping
                  CMSimple is a simple content management system for smart maintainance of small commercial or private sites. It is simple - small - smart! It is Free Software licensed under AGPL
                  • koen
                    • Mar 2020
                    • 363
                    i have on the phantom a MTC stinger and a large TFL rudder, TFL hardware is good maybe not the very best but good for a nice price
                    • BrickBait
                      • Jan 2019
                      • 50
                      Thank you for that. Good info to get started with.
                      Alfa, those rudders are massive!
                      Should it be WD200 I would probably go with the smaller version.
                      Cheers - Frank
                      • BrickBait
                        • Jan 2019
                        • 50
                        Now see this.... That is what I am talking about
                        Cheers - Frank
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4309
                          Originally posted by BrickBait
                          [ATTACH=CONFIG]177394[/ATTACH]
                          Those are Tenshock carbon rudders and a TFL drive
                          • BrickBait
                            • Jan 2019
                            • 50
                            I don't dig the rudders, but the setup is sweet. I might go that way with some Werner or MTC hardware.
                            Cheers - Frank
