Quest. about solid drive shafts
  • dasboata
    • Dec 2010
    • 3152
    Is it possible to use the solid drives in a cat with a S bend stuffing box ? Hmm ? thanks
  • oscarel
    • Dec 2009
    • 2128
    How would a SOLID shaft BEND?? Most use the slightest bend possible.
    Sent from my SM-S908U using Tapatalk
    • dasboata
      • Dec 2010
      • 3152
      they do bend , that's why I was asking how much !
      • fweasel
        master of some
        • Jul 2016
        • 4291
        By solid drive shaft, are you referring to the piano drive steel wires? If so, I found them to be more trouble than they're worth in small cats with just a single bend, because it was too severe. I can't imagine an S bend setup would even be possible.
        Vac-U-Tug Jr (13mph)
        • RaceMechaniX
          • Sep 2007
          • 2833
          Chris, the simple answer is "NO". unless the S-Bend is very shallow and over a long length the wire will fail. Also the larger diameter the wire the higher the likelihood it will fail.
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • 1coopgt
            • Feb 2019
            • 417
            Your talking about a wire drive, correct? I suppose it depends on how drastic the s bend is.
