22 inch hydroplane setup
  • U.L. HYDRO DRIVER ICE
    • Apr 2008
    • 265
    What would be a good motor and a esc for this boat . I would like to get around 40mph + and how many lipos should I use thanks for looking 22 inch hydroplane setup
  • JimClark
    • 5907
    I have a 1/16th shovelnose that has a 3600 kv Ammo motor and uses a Hacker 70 and a 2s lipo with a Octura X430R prop and it is close to 40 cretainly higher than 35. If you used a 3S and a lower KV I think you would be at 40 or slightly above. Boat is 22.5 long
    Billy Graham
      • Apr 2008
      • 265
      Which model is he motor or the mm thanks
        • Apr 2008
        • 265
        What about using a hacker 8 L 3000 kv and a 100 amp esc with a x435 prop on 2s
        • JimClark
          • 5907
          Here is the link for the motor
          Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
          Not sure on the hacker
          Billy Graham
          • JimClark
            • 5907
            Charles what Hydro do you have hat is 22 inches long?
            Jim
            Billy Graham
            • Steven Vaccaro
              • 8723
              Here is a setup for ya.
              http://forums.offshoreelectrics.com/...ead.php?t=6143
                • Apr 2008
                • 265
                Jim
                It is a 22inch budweiser that 90 s hull
                  • Apr 2008
                  • 265
                  How good would this motor do
                  Great Planes Ammo 28-56-3200 In-Runner Brushless Motor and which prop
                  • JimClark
                    • 5907
                    Porbably have a whole lot of torque so you would most likely be able to handle a much larger prop than my boat can. My boat uses a X430. Never used one but it could work.
                    Jim
                    Billy Graham
                      • Apr 2008
                      • 265
                      Do you think a x 435 would give some speed
                      • JimClark
                        • 5907
                        Would be worth a try on that outrunner. run it for a short time then bring it back in t check temps
                        Billy Graham
