Graphene vs lipo
  • eehess81
    • Jun 2021
    • 158
    Graphene vs lipo
    Hi all, was wondering what people opinions are on graphene batteries. Are they much better than regular lipos? Last longer? Better power output? Any info is appreciated, need to pick up a couple new batteries.
  • Panther6834
    • Apr 2020
    • 708
    Personally, I can't say whether they have "better" power output...I don't have equipment for testing that...but, they do have "higher"power output. Standard LiPos charge to 4.2V/cell, whereas LiPo Have charge to 4.35V/cell.
    Of course, that's only if you have a charger with a LiPo HV setting, and actually use that setting. If you're charging them on a non-HV capable charger, or if you charge them as a standard LiPo on an HV-capable charger, they'll only charge to 4.2V/cell, thus you end up 'wasting' that additional power capability...however, by doing so, you could extend the overall life of the battery. I have no personal data to back this up...but, based on testing by others, it does appear to hold true.
    As for the rest of what you asked, hopefully others will chime in.
    ~ More peace, love, and kindness would make the world a much better place
    • koen
      • Mar 2020
      • 361
      I use Graphene Panther batteries and find out they pack more punch not so much more run time
      • fweasel
        master of some
        • Jul 2016
        • 4291
        Based on my understanding of graphene molecular technology, I think the term, when used with Lipo batteries, is mostly marketing. However, most graphene series lipos perform quite well as they tend to be the top tier offering from the manufacturer. I've had excellent results with both generations of the Turnigy graphene packs, the original 65C and the newer panther 75C. They take more abuse, balance out consistently, and have always tested well in abusive independent battery tests. China Hobby graphene packs also test very well and are assumed to be the same cells as the panther based on testing results, but are sold at a lower price point.
        Graphene vs. non-graphene has nothing to do with standard Lipo vs LiHV (4.35V) packs. Revolectrix was one of the last high C rating HV lipo producer and they've recently closed up shop. Very few in the FE hobby run LiHV packs.
        Vac-U-Tug Jr (13mph)
        • eehess81
          • Jun 2021
          • 158
          Ok thanks. So does a 50c graphene pack out out same power as a 50c lipo pack, just the graphene may stay cooler and last longer? I've read they also can take more cycles.
          • Panther6834
            • Apr 2020
            • 708
            Originally posted by fweasel
            Graphene vs. non-graphene has nothing to do with standard Lipo vs LiHV (4.35V) packs. Revolectrix was one of the last high C rating HV lipo producer and they're recently closed up shop. Very few in the FE hobby run LiHV packs.
            Yup...I can admit when I goofed. And, yes, standard graphine LiPos aren't any higher in voltage than standard LiPos.
            • fweasel
              master of some
              • Jul 2016
              • 4291
              Think of Graphene more as the top trim level for a particular brand. The graphene version is likely a better performer in most categories than the non graphene version from the same manufacturer. It's a little more difficult to compare batteries between manufacturers, and best to rely on independent test results.
              • eehess81
                • Jun 2021
                • 158
                Ok that's a good way to look at it..thanks.
                • jkflow
                  • Aug 2021
                  • 329
                  Unfortunately, nowadays, the term 'Graphene' is more marketing than anything else. That was different several years back, where some had better performance over standard lipos.
                  A good read up in general about true performance is below. Feel free to read through all of it or stick with the first page and get an idea of 'real C, all lipos are in the 30-35C range regardless of advertised values with few top performers.
                  You do NOT need the top performers though for general stuff. Use it as a guide to pick the cheapest or compare prices to real performance.
