Veneer on birch skins?
  • jingalls007
    • 1015
    This will be my first attempt with wood veneer so any input or experience is more than welcomed.
    The steps I?ve planned out unless anyone has different suggestions:
    1) West systems slow-cure thinned for sealing the birch.
    2) While wet, lay down veneer on birch skins, clamp, let dry.
    3) Then seal veneer, let dry.
    4) Shape skins, clamp to sponsons, trim veneer and birch skins.
    Does this sound right? Should I build the boat then add the veneer then seal?
    The veneer is rainbow poplar. It?ll get sealed, then 4-5 cotes of clear.
    Thanks doodes!32FCD444-F7FA-4D66-BD5F-AF74FEBD5829.jpg97BF1432-152E-4F6B-8AC2-DA27FA5CEF99.jpg
  • Shooter
    Team Mojo
    • Jun 2009
    • 2558
    I thought we'd hear from somebody by now. I've skinned a lot of boats in my life, but never veneer, but your method sounds reasonable to me. Probably how I would do it.
    • Jesse J
      scale FE racer
      • Aug 2008
      • 7128
      The only “veneer” I’ve done is 1/64” ply on 1/8” balsa.. so gotta say, Jarrett I’m not sure what you are up to..
      "Look good doin' it"
      See the fleet
      • jingalls007
        • 1015
        They turned out ok. One more seal coat should do the trick.
        • Shooter
          Team Mojo
          • Jun 2009
          • 2558
          Looks great!!
          • T.S.Davis
            • 6220
            I did this with Lacewood. I should have done it the way you did. I adhered after building. Lacewood is super fragile. Such a pain in the a$$.
            Noisy person
            • jingalls007
              • 1015
              I had a few areas lift on the right sponson so I used thinned down G flex for the left sponson, instead of the WS 206, and it turned out damn-near perfect.
              I haven’t seen lacewood. I’ll check it out. My 8th scale will get curled maple dyed to look like an old fender “flame” Stratocaster.
              • jingalls007
                • 1015
                Originally posted by Shooter
                Looks great!!
                Thanks man! We’ll see what the final product looks like here in a few weeks.
                • jingalls007
                  • 1015
                  Finished. They turned out alright.
