H&M mono torque roll
  • MarkF
    dinogylipos.com
    • Mar 2008
    • 979
    Well part of your problem is your turning left. Boats only turn right because of prop torque. Make right hand ovals only and it will drive better.
    • vvviivvv
      • May 2009
      • 1091
      Yeah, it's setup really to turn both ways, I got another run in a few days ago and got 81mph again, I think a trim tab was bent from that previous crash I hadn't noticed.
      It doesn't like the S255 prop, went back to 457 and runs fine again. GoPro kept cutting out after 1 min but here is the start of the run anyway, I got a few high speed passes on the glass water, it then took a tumble and ripped it's hatch mount out a little bit, no real damage really.
      Heres the video with the 457 back on (currently uploading)
      Uk SAW record holder
      • MarkF
        dinogylipos.com
        • Mar 2008
        • 979
        Both ways means you let off on the throttle a little before turning left. Your not suppose to turn left at full throttle. It kicks out the back end of the boat which you already know now.
        • vvviivvv
          • May 2009
          • 1091
          Tbh, it's my first fast mono, and jumping in with a 80+ boat is a quick learning curve.
          the issue is the chime walk, it's handling in corners is great.
          boats better on x457, it's going to be a few months till I can test again unfortunately.
