Sprint 36 race motor
  • Bushmen77
    • May 2016
    • 82
    Need help pease,
    What motor do you guys like to use for heat racing and props with it ?
    • 8012
    When I oval raced mine I used a Neu 1527/1Y on 6S spinning a pitched-up x455 or ABC 2116/17* for speeds in the low/mid 60s. That was plenty fast to win heats in rough race water.
    • Bushmen77
      • May 2016
      • 82
      Wow x457 prop big wheel glad to here that’s.
      Any others appreciate it.
        • 8012
        The motor is of relatively low Kv, and the prop was run high with the centerline about 1/2” above the bottom of the sponsons. It’s possible to use a higher Kv motor and smaller prop, but most of us found this setup preferable for heat racing.
        • Bushmen77
          • May 2016
          • 82
          Hay thanks for the help. I am only running 1/4 up on strut so I can help it out there for sure.
