Is there anyway to fuse the ESC or motor to prevent it from burning up.
Fusing
Tags: None
Yes but better is to stay within the rated specifications of the equipment or are you repairing a drive?
Regards
Hubert -
Seaweed got wrapped around prop and must have overloaded. I thought the battery was depleted but it wasn?t.Comment
Did it burn up the controller? U say Seaweed if this means you run in salt be sure to flush the cooling system with freash water afterwards. U can use W ater D ryer 40 to remove all the moisture when you are done flushing the system.
Regards,
HubertComment
