Tp 3630 1950kv
  • obrien
    • Nov 2007
    • 1264
    Tp 3630 1950kv
    Looking for some suggestions. I recently swapped in this motor so that I could use the leopard on a different hull. I have had one test with the boat and found it to be substantially slower even when I went up to the next size in prop.
    The original setup was a leopard 3660 2050 kv with an abc 1715
    I ran the tp with a 1717
    I have been trying to figure out what timing is recommended for these motors. I?m going to be testing more on Friday and hopefully I?ll find a solution but I am obviously looking into recommendations
    My test was roughly the equivalent of a heat race. I found the motor to be about 145 degrees, esc was 105, and batteries about 92 degrees.
  • martin
    • 2887
    Your TP3630 - 1950kv is a D wind motor, needs low timing 0 - 5 degrees. The 1717 prop has a lot of pitch for this motor so may be pushing temps up.
    • obrien
      • Nov 2007
      • 1264
      thank you Martin. I appreciate the feedback. I will be verifying the timing when I get the program card in my hands on Friday and I plan to play with more props as well
      • Peter A
        • Sep 2012
        • 1486
        The next size prop is a 1716, the UL19 and Zelos prop.
        • obrien
          • Nov 2007
          • 1264
          It is a 1716. I fat fingered my phone
          • obrien
            • Nov 2007
            • 1264
            Changed the timing in the esc and it helped the motor quite a bit
            • martin
              • 2887
              That is good to hear.
              • Steven Vaccaro
                • 8723
                What timing did you end up with?
                • obrien
                  • Nov 2007
                  • 1264
                  0 degrees
