You guys think i should try another ? Might have just been a fluke or there just junk.
HiModel 4s-8s 200 amp esc
Just put the 8s Hymodel in my formula hydro i just built. Worked great until 3rd set of batts and its now dead. Only goes to program mode and wont even do that. Dont know if i should try anotther one or just upgrade. I was useing a 7 xl with a 442 prop . It went a 49 best with no heat issues so i was happy.........untill it crapped out!!!! OHWELLTwin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/Comment
Hi i was running the early version of this esc http://www.hobbycity.com/hobbycity/s...12S_BESC_(Ver4)
in my lizard xtreme with Kb458xl abc H5 prop i burned the MOSFets on the 3rd run probably drawing too many amps it was magic to program with the card im now have an Etti150 race and love that esc not so easy to program but if you take your time you can get it right
Here is the vid
Cheers AdrianComment
Hi i hit a branch that was in the water close to the edge ripped the rudder off the bracket killed a 6kg metal gear servo no damage at all to the hull
very lucky here is a picture of the boat with the new esc
CheersAttached FilesComment
Yeah...really really lucky it just ripped the rudder, u should use a rudder with break off option just to be safe, that is a wholesome caps u got on your esc, I think it awsome, I've seen a someone use it on a bandit cat with a top speed of 127km/h.
Stiletto tunnel,EPV135 (53") twin cat, CT06"Spirit of Qatar", FD 47" mono, Twin Mini Cat 23.5"Comment
I have to say this is my second Etti esc the caps exploded while i was running the boat with the first Etti blew the taped lid right off the boat LOL and lost itthis is the one that Dee at etti replaced for me and he suggested to add the caps
AdrianComment
Nice run. I would use a 42-43 mm prop. to be a little safer and when you want speed the 45mm. Your system must be drawing 130-150 amps with the 45mm.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
Would any of you know of a way to activate the HM for full throttle only without the use of a receiver? I'm working on a project where I only need to run full throttle for 5-6 sec. I would like just to have a switch connected to a timer to activate the ESC and then shut it down. Any ideas? Thanks in advance.
TerryComment
I have a rudder with two water intakes. One goes to the motor (not installed in the pic yet) and the other one is splitted by the "T" to two tubes on the ESC and then the two lines exit through the side of the hull still separately. The third exit line is from the motor cooler... Clear?Comment
