Big oops........ Help.
  • vvviivvv
    • May 2009
    • 1079
    Hi guys, was finishing off my HPR build, dropped a clanger..
    Overtightened a 3mm hex and rounded it, turns out its a micron too deep (despite me measuring everything up with correct size washers / bolts)
    Anyway theres a point on the Lehner 'Hi-Amp' fan when I rotate the shaft it catches, Any suggestions on removing this? all I need to do is loosen it half a turn...
    Uk SAW record holder
  • StevenBryant
    • Nov 2012
    • 359
    Hi Liam
    I am sent you a link to some high tensile SS bolts to use on PM.
    To resolve you problem, use a Dremel to cut a slot and use a flat head screw drive to unscrew.
    Sent from my iPad using Tapatalk
    • fweasel
      master of some
      • Jul 2016
      • 4286
      I agree, slot it with a dremel would be my first fix. Sometimes I've been able to get a bite using a larger standard sized allen or even a torx bit in a stripped cap screw.
      Vac-U-Tug Jr (13mph)
      • vvviivvv
        • May 2009
        • 1079
        Dremel is my last resort, little bit scared of getting metal filings in the motor too..
        I've epoxied a Allen key in the bolt and will try in the morning..
        • Doby
          KANADA RULES!
          • 7280
          Epoxy might not be the best...try JB Weld if the epoxy fails.
          Grand River Marine Modellers
          • NativePaul
            Greased Weasel
            • 2760
            Often you can hammer a Torx driver into the hex to get one out.
            • vvviivvv
              • May 2009
              • 1079
              It was super tight, no room to get anything at it... Anyway, got it out with a hammer and a punch, all it took was to release a tiny bit of tension and it came out.
              Although I have now built it, went to setup my ESC and the speed controller decided to just smoke........
              • properchopper
                • 6968
                Liam, (or anyone with a similar dilemma) -
                Having "been there" many times over the years (building boats & motorcycles) I've used this solution - needle nose vice-grips snuck into place & squeezed waaay tight & after a few tries to get it lined up it works most of the time. Often helps to recite obscene proverbs while applying pressure.
                I see you have that one solved as I was posting this. Enjoy your new ESC [Oh wait ]
                • enzo thecat
                  • Jul 2013
                  • 42
                  I just hate when this happens. Often times, i swap out as much bolt/screw/nut hardware with American made synonymous hardware. It has helped A LOT.
