Thrust washers
  • stadiumyamaha
    • 1284
    Thrust washers
    General consensus.
    One or two thrust washers?
    white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
    • 7673
    At the prop? I just run one.
    • stadiumyamaha
      • 1284
      Yeah. In front of the dog. I normally run one as wel but thinking two may be less friction. Just wondering.
      • rol243
        • Apr 2017
        • 1038
        no thrust washers needed. if the drive dog touches the thrust washer , you know the dog is too close to the strut. the normal spacing without a washer is the diameter of the shaft ie; 3/16 inch shaft = 3/16 gap between these both surfaces. any contact only causes drag and over heating of electronics.
          • 7673
          this can depend on flex shaft length and prop load.
          The gap can be played with if one cares to and pays attention. Do I? Umm,
          Now and again. Haha
          • stadiumyamaha
            • 1284
            Thanks guys. I prefer to run one and account for it when setting gap. Would rather wear out the washer than the dog or strut. Was just thinking two would cut down on friction encase it does draw in too tight.
            • Alfa Spirit
              • 2131
              5mm Thrust Ball Bearing is perfect
              • rol243
                • Apr 2017
                • 1038
                yes to be used at motor end of shaft not at strut end.
                • Alfa Spirit
                  • 2131
                  I use the 5mm Thrust Ball Bearing at end of shaft in front of the drive dog, I put WD40 or oïl after esch run that' s perfect, very high efficiency !
                  • rol243
                    • Apr 2017
                    • 1038
                    yes i suppose by having this bearing thrust washer at the strut end , it would stop the flexable shaft from coiling up in tension thus giving less drag to the shaft.
