Recomended RPM range explained
  • Crash
    • Oct 2015
    • 313
    #46
    6 to7 mph faster but, boat is not set up to go beyond 70mph
    Its wants to fly
    • Crash
      • Oct 2015
      • 313
      #47
      Originally posted by Prodrvr
      rock n roll man
      Do you think its worth it to try 8s with 46mm prop to reduce amp draw? It will still be in upper 60s mph
      • photohoward1
        • 1610
        #48
        Bring some marshmallows on 8s
        • Crash
          • Oct 2015
          • 313
          #49
          ok. thanks for that ;0
          • Nikolas Andriop
            • Jun 2015
            • 73
            #50
            What esc do you have??
            • Crash
              • Oct 2015
              • 313
              #51
              Sf 300 x
              • Crash
                • Oct 2015
                • 313
                #52
                DID A bench test of the 8s
                Rite away the set up got hot, that's not in water . just a couple of pulls to get data..
                It only spun 35k rpm and pulled over 300 amps. Seem like that's not rite. No load and 300 plus amps. I have to look at it tomarrow Again.
                I'm starting to think that this motor that Chris fine sold me is a 1650kv not 1750kv
                • Prodrvr
                  • Jul 2015
                  • 701
                  #53
                  Which motor is it?
                  • Crash
                    • Oct 2015
                    • 313
                    #54
                    Which motor is it?
                    Tp 4060
                    • Crash
                      • Oct 2015
                      • 313
                      #55
                      I used one 5s lipo and one 3s lipo
                      Obviously not. A matched set...is that a problem for the esc?
                      • Prodrvr
                        • Jul 2015
                        • 701
                        #56
                        As long as the esc can handle 8s, you're good.
                        • Prodrvr
                          • Jul 2015
                          • 701
                          #57
                          Tp 4060
                          What's the max voltage for that motor?
                          • Prodrvr
                            • Jul 2015
                            • 701
                            #58
                            I looked it up. It's good for 8s so I'd go with that.
                            • Prodrvr
                              • Jul 2015
                              • 701
                              #59
                              I have two TP 4070 2080Kv motors that I'm throwing in a Zonda build. They're rated for 6s max, so that's what I'll be running them on.
                              • fweasel
                                master of some
                                • Jul 2016
                                • 4287
                                #60
                                What timing are you using with that TP 4060?
                                Vac-U-Tug Jr (13mph)
