I'm trying to hook up lipos in series. Do you guys DIY, or do you buy them some where? Also,10 or 12 guage?
Deans Ultra Y harness
Dean's makes one...here's link:
Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
Parallel version:
Castle bullet connectors are less resistant and are better at preventing sharp voltage loss. DIY is best.
Read this post by Steve.
http://forums.offshoreelectrics.com/...ead.php?t=5740Comment
Bullet Connectors:
http://www.offshoreelectrics.com/products.php?cat=39
Series Y Harness:
http://www.offshoreelectrics.com/pro...d=ose-yharnessMike Chirillo
www.capitolrcmodelboats.com
If you aren't sucking insane amps, you won't notice th difference. Thinner wires will run hotter. The Deans connectors will be hotter than the wires, but that's normal. But then, only if you run insane amps.
AndySpektrum Development TeamComment
How about a 12 guage Y connector with 5.5mm connectors to the esc, and two Deans connectors to the Lipos in series?Comment
If you have bullet connectors on the lipo's and esc and the leads are long enough you don't need anything. Just plug in the positive from one lipo to the esc and the negative to the positive on the other lipo and the negative from that lipo to the esc. I hope this is NOT clear as mud.IMPBA 20481S D-12Comment
What i meant was one end of the Y has two 5.5mm bullet connectors, and the other two ends of the Y have two Dean connectors. The 5.5 mm bullets are
connecting to the ESC. While the two Dean connectors are pluging into the Lipos.Comment
Deans connectors are for upto 60 Amps. If your setup uses higher amps the best thing is to have bullet connectors (5.5-6) on your batteries and ESC. As Egneg stated above if you have the following combination of bullets and your cables are long enough you just don't need an extra Y harness:
Batteries: Red -Male, Black- Female
ESC: Red -Female, Black-Male
Plug the Nr.1 battery red to the ESC red, the Nr.1 bat. black to the Nr.2 bat. red and the Nr.2 bat black to the ESC black. This is just for info. and guessed that should mention.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/Comment
Thanks Disar! I didn't know that Deans is rated at max 60A... So using two 4000mah 20C 3S1P lipo packs in series will be too much for a Deans Y-harness? 2x (4x20=80A) = 160A through one Deans to the ESC would melt it, right? Or can I take the chance? How do I keep the two bullets on one pack from touching each other and short-circuiting?Comment
In theory the Deans are fow max. 60A and stated in the OSE site:
The Amps that you mention are the max.Amps that your batteries can deliver and not the actual Amps of your setup. The only way to find the Amps of your setup is to use an Eagle tree system or the OSE method:
http://www.offshoreelectrics.com/conversion.htm
My proposal is not to take the chance with the Deans and use the bullet connectors (4 or 5.5 or 6 mm). I also changed to bullets because my Deans were getting hot (not melted) at about 70 amps. Also you see that the contact area of a Deans connector is smaller than that of bullet.
To avoid short circuit and wrong polarities you fit a male bullet on the red(+) and a female on the black(-) with heatshrink tubing. In that way you cannot have short circuit or confuse positives and negatives. An on the ESC you fit a female on the red and a male on the black and if your cables are long enough you can plug as mentioned above. If the cables are short then you will have to make a harness. I will add a photo if you like.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
