Help! Broken canopy latch!!
  • Krazykenny
    • Mar 2018
    • 37
    Ive found that on undoing the canopy latch on my JOYSWAY SEA RIDER LITE 4 ,the plastic canopy latch has broken and disintegrated, can anyone please advise where i could possibly get a replacement?or if there is anthing else i could use to keep the canopy fastened down , i would prefer metal or rubber rather than more plastic, but willing to try anything really. Its that desperate.
  • MADRCER
    • Feb 2017
    • 759
    Kenny,
    How desperate and where in the WORLD are you finding all these boats....This one should work or be modified to work...
    Sikowd memberikan layanan deposit terlengkap dari bank apa saja dan deposit via qris super cepat hanya 1 detik langsung masuk ke akun anda, Nikmati keseruan tanpa batas dengan deposit super cepat dan peluang menang super besar di setiap permainan.
    • Krazykenny
      • Mar 2018
      • 37
      Thanks for the suggestion, but the cost to get this part in the UK is horrendous. Im wondering if its a UNIVERSAL type of fitting whether other makes of same size like helion or volantex might fit , its only a two piece plastic swivel latch and possibly any 17inch boat using similar might do the trick? Maybe helion rivos xs? Or the volantex racent 17 ? Or suchlike its a small part about 4-5 mm diameter.on the shaft part.
      • NativePaul
        Greased Weasel
        • 2761
        The obvious answer is tape which is pretty universal for all boats, but maybe you could make a catch from an unused servo horn with a bolt through it?
        • NativePaul
          Greased Weasel
          • 2761
          Do you think something from this pack may work?
          Virtually all UK model shops distribute for ripmax, so your loclal model shop should be able to get one in with no postage costs if so.
          • Krazykenny
            • Mar 2018
            • 37
            Thanks guys,iv e ordered a helion xs latch which i think should be the right size,in that it is about smallest size its humanly feasible to use,so should be o.k.thanks to everybody for your help and suggestions.
