TP 4050 1950kv on 6s
  • R2315
    • Aug 2016
    • 199
    #76
    Originally posted by danzuby
    I may start looking for another hull to start building on.
    There is always good stuff coming and going here, just keep looking everyday and you will no doubt find a gem. Good luck!
    • danzuby
      • Dec 2017
      • 37
      #77
      Thank you.
      • danzuby
        • Dec 2017
        • 37
        #78
        Originally posted by Speed3
        I suggested the lower kV 1650 4060 because I have learned lower kV is much easier on the electronics.
        The 1650kv combine with a m545, m645 should pull amps in the same area as the 1800kv x642 setup.
        But the m545 is a faster prop than the 642 and the tp 4060 will hold the rpm better underload. So I feel by reason of prop efficiency and motor efficiency. You should see better speeds than what you did before.
        Sounds good and makes perfect sense thanks for your time.
