For a bit more to get me more deeply interested in fast electrics I have purchased a Hobbyking Libero shovelnose. As I await its arrival I need to sort out a few details.
Firstly, this is the ESC I hope to use as I want to use this type of ESC on a current 70 cm mono project and wanted commonality.
https://hobbyking.com/en_us/turnigy-...r-cooling.html
Secondly, being overly cautious, I wanted a dual pickup rudder, however, after trawling through over 700 rudders on eBay the only dual pickup rudders available have a different pivot mechanism and so a direct replacement rudder to the existing hardware is apparently not possible. Any thoughts please. I could opt for a through hull pickup as an option. I wanted separate motor/esc cooling paths.
Edit: I found this rudder at RC Boat Bitz. This looks like it could be modified to fit or might be direct install. It is 100 mm deep. I could trim a little from the lower edge if too deep. I am only looking at the rudder itself and not the rudder arm mount bracket.
http://www.rcboatbitz.com/index.php?...oducts_id=1445
http://www.rcboatbitz.com/index.php?...oducts_id=1955
