My Libero arrived today and I set about fitting the dual water pickups and large tubing throughout. The stock motor is a 3660 2070kv. I am awaiting a 3674 which I may possibly fit coupled to a 40 mm 2-blade or possibly a 38mm three-blade propellor. Apparently, a 42 mm 2-blade is a little too much for the stock motor. The stock shaft is a 4mm one piece flex.
With the battery restrained by two hold down straps the CG is just less than 2 inches aft of the sponson. If I move the battery forward slightly then there is provision only for one strap. Oddly only two straps are able to be fitted to the battery tray. I will not be able to test run until next week, however, everything is tested and ready to go.
