J.A.E .21 pulling to the right ?
  • Andris Golts
    • Jan 2011
    • 506
    Hi all recently upgraded the JAE .21 with a 2200 kv motor with speeds approaching the 60 mph mark im observing the rigger is starting to pull to the right on the straights the rudder is set straight and the stock turn fin is mounted as per instruction book.Im considering shimming the turn fin using # 4 ss washers to pull to the left . Should a properly set up outrigger not pull slightly to the left while running down the straight aways with all steering corrections to be made turning the right ? What else can i do to remedy this situation ? Regards Andris Golts.
  • urbs00007
    • Jun 2011
    • 826
    first thing, sharpen that prop. if that doesn't do it, you can shorten the distance of the left sponson to the hull. this puts more weight on the left sponson and will help the boat track straight. try 1 inch.
    • rol243
      • Apr 2017
      • 1038
      also with the stock turn fin you can either raise or lower the front of fin to correct any left or right pull., the right sponson needs about 1/16 inch of tow in to correct pulling to the right at speed. your adding more rpms to the prop so as mentioned make sure the prop is quite sharp and not to large in diameter . what size prop are you running now ?
        • 7990
        All the above suggestions might work, but in reality most hydros will pull to the right (not left) without some left rudder trim. This is due to prop walk along with drag from the turn fin. Mine uses about 1/16" of left deflection at the rudder trailing edge to run straight in the upper 70s.
        • zooma
          Local club FE racer
          • May 2014
          • 652
          Andris,
          Despite that problem, it's good to see the kind of speed you are getting. I have a 2200 kv motor for that boat, just waiting for a chance to install it. I only have the 1450 mod props. Is that what you are using? Any other modification beyond S&B?
          Ron - The Villages, FL
          • Andris Golts
            • Jan 2011
            • 506
            Thanks to all for the excellent information. Regards Andris Golts.
            • Arizonaheat
              • Mar 2013
              • 43
              Any bias on the rudder will create drag and slow you down.
              I run a 21 in the mid-70's on 5S.
              You just need a little toe-in and perhaps a better (custom) turn fin...the stock one isn't very good.
              • rol243
                • Apr 2017
                • 1038
                may i ask whats wrong with the stock fin ? my 2 jae,s run with the stock turn fins and they both track dead straight and turn very sharp.
                • Andris Golts
                  • Jan 2011
                  • 506
                  Hi all did more fine tuning on the JAE .21 i made a 1/16'' toe in adjustment on starboard sponson checked the port sponson for paralell to tub discovered bow end was out by 1/64'' corrected that situation filed a razor edge on the turn fin although the aluminum material seemed a bit soft for my like ing re-balaned and re-sharpened all props i plan on using on the rigger. Went out tonight for testing and noticed a huge improvement in handling not pulling to the right nearly as much i still may try moving the port sponson 1'' closer to the tub. Once again a big thankyou from everyones suggestions . Regards Andris Golts.
                  • rol243
                    • Apr 2017
                    • 1038
                    you should be able to leave the sponsons set at there original spacings, just add the tow in to the starboard sponson front plus keep the turn fins top level with the top of tub [ horizontal ] hey whats your full power and prop set up now Andris ?
                    • zooma
                      Local club FE racer
                      • May 2014
                      • 652
                      Andris, do you know what speeds you are getting now?
                      • Andris Golts
                        • Jan 2011
                        • 506
                        Hi all worked my way up to x445 prop gps reading 58.1 mph still have several props to try. i would like to get to the 65 mph range with this motor esc combo if possible. Regards Andris .
                        • zooma
                          Local club FE racer
                          • May 2014
                          • 652
                          sounds great
                            • 7990
                            You simply do not have enough prop to go much faster. Try an ABC H-7 or similar prop, that should get you comfortably into the 60s.
                            • rol243
                              • Apr 2017
                              • 1038
                              just be carefull not to over prop as this will heat electronics and battery packs up quick. i prefere a smaller prop for oval race and naturally a larger prop for s.a.w. just been playing with a slightly moded H4 prop for oval and results are quite good compared to my previous H7 prop which did produce great speed but made things get hot rather quickly.
