Motor cooler spacer
  • denboy01
    • Sep 2007
    • 59
    Motor cooler spacer
    I've made up a spacer between motor mount and motor that allows air to flow through the motor, anyone tried it before?
  • pescador
    • May 2009
    • 499
    I used to have one with fins cut in it for my old brushed car motor.
    Sent from my iPad using Tapatalk
    Namba District 16
    • NativePaul
      Greased Weasel
      • 2761
      Air cooling is certainly a worthwhile extra if your motor has the holes nescisarry.
      That looks very nice, but if I had the skill to make that, I would make a motor mount similarly shaped instead of the spacer, saving some weight, and getting a smoother air path.
      • denboy01
        • Sep 2007
        • 59
        Having now tried it out I think that as the air inside a sealed hull warms up that any extra cooling effect is lost
        • TRUCKPULL
          • 2975
          Don't give up on it,
          Every little bit helps.
          I put the extra holes in my motor mounts on every boat that I can.
          Larry
          • 785boats
            Wet Track Racing
            • Nov 2008
            • 3169
            Look at it this way.
            The air in the hull never heats up to anywhere near the temperature of a motor. So it will have a cooling effect.
